Quote:
But wouldn't a thick 5W-30 still in theory give you better gas mileage than a 5W-40, 10W-40, or 15W-40 oil.
Very slightly, maybe. But I have yet to find a single person who would claim that GC 0w-30 gives him better MPG than M1 0w-40.
And if BWM really wanted to influence their CAFE numbers, they'd be recommending 0w-20 oils.
Quote:
The reference I was using for BMW recommending heavier motor oils in the Europe for the same engines than in the US is here:
http://www.bimmerfest.com/forums/showpost.php?p=5223105&postcount=1
The post looks legit to me, I don't think they went through all the trouble to doctor the BMW manual to help them prove a point about motor oil.
While the post looks legit, I think the author is reading too much into this and trying to selectively pick facts to suit his theory. For example, he writes:
Quote:
if you have your North American manual, notice on the relevant page inside it (designed just like the one below), it specifies only 5w-30.
The owner's manual of my 2002 530i states:
Quote:
Viscosity ratings
Viscosity is the oilflow rating as estab-
lished in SAE classes.
The selection of the correct SAE class
depends on the climatic conditions in
the area where you typically drive your
BMW.
Approved oils are in SAE classes
5W-40 and 5W-30.
Also take note of the "Special Oils" on the right side of the chart that he posted. I believe we discussed these here on BITOG in the past, and conclusion was that these are oils meeting the BMW LL-98/LL-01/LL-04 spec. They can be of pretty much any grade and still be used across all ambient temps.
It's true that BMW (and most other mfgs) used to recommend thicker oils in the past (15w-40 and/or 10w-40), but I think that is mainly due to the fact that those were the most common grades back then. With the invention of affordable shear stable synthetics, it is now possible to achieve the same level of performance with even Xw-30 grades, while providing superior cold startup protection and allowing for extended drains. Whereas that 15w-40 mineral oil would not be able to withstand a long drain OCI.
