Got these answers from a PWC site for someone else with hyfro lock-
All skis have a water inlet hose. It's what feeds the engine cool water.
Did you tow it before or after you cleared the hydro lock?
If it was before... then you are fine. Towing without picking your feed hose will fill the engine with water... but since yours was already full... it wouldn't make a difference.
Since you have cleared the engine... and you ran it hard... all the water will be out, and oil will be in. You should be fine with a regular flushing.
Answer #2
Posts
51
Watercrafts
yamaha waverunner1997, 1996 seadoo gsx 1996
Feedback Score
I have been told that if you dont pinch the water inlet line when you tow it it will fill with water. I am guessing that by towing it the prop must be turning and pumping water into the motor with no way to remove it cause the engine is not running. Mine has been flooded with water twice. Both times I got it running and have no bad effects yet and its been a year since the last mishap. I just pulled out the plugs spun the motor till no more water came out. Cleaned the plugs and tried to start it. I did this about 7 or 8 times each time drying the plugs and re installing them. It eventually started.
#3
Nope the prop isn't spinning. When you pull the boat/ski, you are forcing water though the pump... and in turn, into the engine.
Fubada...
If you look at your transom from inside the hull... you will see a 5/8" (or so) rubber hose just at the top corner of where your pump is bolted to. That hose will be going to the head of the engine. That's the hose you need to pinch off. A regular hose clamp won't work... you need a pinching device. They can be bought at your local dealer, or autoparts store.
