Auto-Rx is applied at a ratio of 2 ounces per quart (more is not better ) your extra Auto-Rx
should be used after cleansing and with your second oil change add 3 ounces of Auto-Rx to your new oil. You will be able to tell the benefits and it is very reasonable insurance that your compression and combustion will stay at max levels. Use one ounce in your power steering and just leave it there, you will stop any leaks or
stop rhem from forming.
