I'm interested in your opinion about the best oil for the Land Rover Defender Td4 which use the Ford Duratorq 2.4 Diesel engine (it's the same engine of the Ford Transit).
Owner manual recommend to use only FORD WSS M2C 913C or ACEA A1/B1 lubricants that are 5W-30 low-friction, low HTHS and energy conserving oils.
Most Defender owner are concerned that this kind of specs don't allow a full wear protection especially in summer season or when in hot desert like environment.
I'm tempted to use a 5W-40 API CF / ACEA A3/B4 but after reading that engine designed to use hyper fluid oils are built using low tolerance bearings, bushings etc. and can be damaged by using mid/high HTHS oils.
What's your opinion about and which oil do you think is more suitable ?
Thanking in advance for any advice.
