I just finished running Rx using ExxonSuperflow for 800 miles. I had Toyota change the oil bc it was too cold. Not sure what the results were but I'm curious to see if oil consumption goes down and Mpg goes up. I looked at the oil before taking it in and it was very clear. I think the engine was already clean from running M1 at 5k mile intervals. That plus adding S2000 afterwards probably really cleaned it up. So, not much to report, but I will definitely keep an eye on the oil/mpg levels. I think if your running a good synthetic, Rx every 100k miles would be sufficient. I think using a high end synthetic and changing the oil at 5-6k mile intervals should keep the engine very clean. Doing this probably negates the use of Rx.
[ February 16, 2003, 02:14 PM: Message edited by: buster ]
