Originally Posted By: mrflex65
Originally Posted By: dailydriver
Originally Posted By: threeputtpar
When the PCV system in my Audi froze on a cold December morning, it burned 1.5 quarts in the 10 mile ride home from my friend's house. It fouled the plugs and threw a CEL for misfires on all cylinders.
My car/LS1 engines actually has/have a PCV valve 'heater wire' for this express purpose (a heat conductive wire with a metal band which wraps around the valve inside of the rubber mounting grommet).
Sometimes the GM drivetrain engineers DO think of everything!
I never heard of this!My 2002 z28 never had it.I'm assuming it was factory installed?
GM has had heated PCV valves on
some vehicles for a while now. I'm pretty sure there were heated PCV setups and catch cans on some of the Quad4 engines back in the 90s.
Ford, by way of comparison, will confuse things by offering a particular year/model/engine combination with three PCV valves, one unheated; one electrically heated; and one heated with engine coolant. To order a simple PCV valve through a dealership you have to actually look at it or get the calibration ID because a VIN may not be enough information to know which part is used. I guess they had a better idea again.
