Looking for info on two quick spray waxes.........
by demarpaint
05/01/16 04:43 AM
The Heroin Epidemic In The U.S....
by qwerty1234
05/01/16 01:28 AM
Air filter wrap
by Duffyjr
04/30/16 10:21 PM
15W-40 Delo, Delvac or Rotella For KUBOTA turbo
by pburchett
04/30/16 09:50 PM
Traveler synthetic oil a slow seller?
by Electromotive
04/30/16 09:34 PM
Tyre rubber, methanol, and bore wear
by Shannow
04/30/16 09:34 PM
What to use in 99 Buick Lesabre OCI?
by Duffyjr
04/30/16 09:26 PM
Help w/Transmission Drain/Fill 08 Honda CR-V 4wd
by klt1986
04/30/16 08:58 PM
pennzoil ultra platinum pure plus
by Brayden
04/30/16 08:10 PM
Group 5 synthetic oil
by Brayden
04/30/16 08:07 PM
Pennzoil Ultra platinum at Walmart
by RubentheIowan
04/30/16 08:03 PM
G-05 Change intervals, 3 or 5 years?
by Canadastang
04/30/16 08:03 PM
Doxxy, Jetstreamz06, TalNum, Spinnizle, JustinL
57758 Registered Users
52 registered (Bandito440, bmod305, BobFout, bbhero, AirgunSavant, BobsArmory, 1 invisible), 801 Guests and 93 Spiders online.
57758 Members
66 Forums
248282 Topics
Page 1 of 2 1 2 >
#1019471 - 10/29/07 05:02 AM Were going back to Regular Diesel at work
Rob Taggs Offline
Loc: Lansing , Kansas
Got the word today that KDOT, the agency I work for is going back to regular old diesel from the biodiesel blend. Was told that the blend we are using only has a shelf life of 30 days and after that acids start to form in the fuel. As proof I was told that equipment that has been sitting for a length of time are having fuel related issues with the biodiesel. Mainly fuel delivery systems are failing.
#1019472 - 10/29/07 01:37 PM Re: Were going back to Regular Diesel at work [Re: Rob Taggs]
Shannow Online   content
Loc: Oz
BD is biodegradable, which is one of it's advantages.
Normal diesel is dosed up with stuff to aid shelf life (mainly bugs and water).
Is the BD just "as refined", or additised ?
Might be some (or a little, or none) difference.
Nissan TD - Edge 5W30 A3/B4
L67 3.8 - Magnatec Stop Start 10W30
Mower - Preconditioned Edge 5W30, plus 5W50/SAE30
#1019473 - 11/02/07 05:47 AM Re: Were going back to Regular Diesel at work [Re: Rob Taggs]
moribundman Offline
Heard something about biofuel eating rubber components unless they were made from FKM (fluoro rubber) like Viton.
#1019474 - 11/02/07 06:51 AM Re: Were going back to Regular Diesel at work [Re: moribundman]
salesrep Offline
Loc: lllinois
Still a lot of variables with bio. Winter will be here as well.
"A patriot must always be ready to defend his country against his government."
Edward Abbey
#1025422 - 11/09/07 08:05 AM Re: Were going back to Regular Diesel at work [Re: Rob Taggs]
doitmyself Offline
Loc: MI
Ha! The problem is that you live in Lansing. We too (Lansing, Michigan) had variable results last winter with bio-fuel. Some companies had huge winter problems (trash haulers) while the guy down the street had none.
I've read that problems with the bio component, ultra low sulfer chemistry, and correct additive package are to blame.
Storing bio in an old gunked up regular diesel tank also loosens all the crud up...change them filters often.
"There are things you do that put food on the table, and there are things you do that feed your soul." I am blessed to have them be the same things.
#1042997 - 12/09/07 09:23 AM Re: Were going back to Regular Diesel at work [Re: doitmyself]
XPR Offline
Loc: USA
Use a diesel cold flow improver
A 3,000 mile OCI is a waste! Use a full synthetic oil!
#1043917 - 12/10/07 06:22 PM Re: Were going back to Regular Diesel at work [Re: XPR]
salesrep Offline
Loc: lllinois
This only helps solve the gelling issue not the other issues?
Edward Abbey
#2631528 - 05/20/12 12:22 PM Re: Were going back to Regular Diesel at work [Re: doitmyself]
AVB Offline
Loc: Georgia
I worked at the motor pool on a USMC installation for over 6 years. Biodesel was a mandate for us. I have never seen a fuel tank get gunked up by real diesel fuel. I have seen the build up that results from using biodiesel, we were contantly having to rebuild injector pumps and have tanks cleaned out. The more a truck was used the less problems we would have, but I have know idea where the idea that biodiesel cleans and breaks up old fuel system gunk from diesel. The gunk that biodiesel leaves behind is almost like tar. The only thing I have seen easily remove that stuff is canned carb cleaner. We have had trucks that have never had real diesel run in them have the same problems. So it is not biodiesel cleaning out the regular diesel gunk. It is biodiesel turning into gunk.
#2636548 - 05/26/12 02:59 AM Re: Were going back to Regular Diesel at work [Re: Rob Taggs]
Gene K Offline
Loc: Decatur AL USA
B5 clogs up the 7 micron fuel filter element in my Davco in 1000 gallons of fuel. B20 in about 400 gallons. Thats despite running it for months. Im not saying all biodiesel will do it but the [censored] we are getting locally leaves much to be desired.
If I change to straight diesel from another supplier the level in the housing wont even change in 3000 gallons.
Edited by Gene K (05/26/12 03:01 AM)
Gene
#2639276 - 05/29/12 12:44 PM Re: Were going back to Regular Diesel at work [Re: AVB]
HerrStig Offline
Loc: Boston, MA
Bureaucrats who never get their hands dirty ALWAYS know things the guys keeping the stuff running don't. Usually what they "know" comes out of a "PC" handbook.
Edited by HerrStig (05/29/12 12:44 PM)
#2642826 - 06/02/12 04:42 AM Re: Were going back to Regular Diesel at work [Re: Rob Taggs]
Loc: Oz
Problem is really "biodiesel" "producers" messing up.
It's easy to make the stuff for home consumption. It's harder to make well for home consumption. It's harder still to make the stuff from waste, in good quality for home consumption.
It's stupid to try to step up to try to make money out of "quality" biodiesel, from waste products, from what was a backyard/yardblock operation.
To meet the "standards", you need to use virtually virgin soybean oil in the US, or Canola in Oz, not donut king grease.
#2642976 - 06/02/12 10:25 AM Re: Were going back to Regular Diesel at work [Re: Rob Taggs]
AVB Offline
Loc: Georgia
What I want to know is if any biodeisel really cleans as well as so many people say, or are they just repeating what they have heard. I only have experience with one supplier and I can tell you the fuel we had was terrible. So is there actually good biodeisel out there? I have had a few people tell me I was wrong that biodeisel was not causing fuel system problems that it cleaned up what real deisel left behind. What I don't know is if these people have any real experience with biodeisel or are they just repeating what they have heard.
#2643564 - 06/02/12 11:07 PM Re: Were going back to Regular Diesel at work [Re: Rob Taggs]
Loc: Oz
Biodiesel is an ester, and as such can clean (think auto-rx etc.)
But if made poorly, can carry with it glycerines and other junk that can make a mess.
#2643703 - 06/03/12 08:07 AM Re: Were going back to Regular Diesel at work [Re: Rob Taggs]
JetStar Online   content
Loc: Flatlands of Indiana
The school bus system here suffered some type of algae, or fungus problem that caused them to cancel school. None of the busses would start.
My weakness is I love all motorcycles regardless of brand
2015 Road Glide
2007 Yamaha FZ1
1978 Suzuki GS1000 (now 1085)
#2644765 - 06/04/12 01:11 PM Re: Were going back to Regular Diesel at work [Re: JetStar]
HerrStig Offline
Loc: Boston, MA
Wonder who paid for all the fuel system cleanup and flushing?
Page 1 of 2 1 2 >
