Does this tail pipe pic tell you anything?
by LeakySeals
05/31/16 04:38 PM
Security Camera system
by Alfred_B
05/31/16 04:10 PM
Valvoline is going to be listed on the NYSE
by demarpaint
05/31/16 03:46 PM
Rislone or stp ethanol fuel treatment
by Indiana79
05/31/16 03:17 PM
Super Tech #3614 CUT OPEN
by car51
05/31/16 03:03 PM
Flight Tracker
by Eddie
05/31/16 02:33 PM
Art and ugly are separated by a fine line
by HTSS_TR
05/31/16 02:27 PM
2013 Ram 1500 Vibration Issue
by 757guy
05/31/16 11:21 AM
Speed & Temperature ratings vs cold PSI
by badtlc
05/31/16 10:52 AM
Worthy of a news story??
by andrewg
05/31/16 10:13 AM
Gorilla Shooting...decaying moral values?
by Smokescreen
05/31/16 09:53 AM
Oil Change Frequency - 04 Neon
by racer12306
05/31/16 09:15 AM
ph9, Kurt34556, Skullzaflare, Jakes_Lawn, Aarrghhh
58031 Registered Users
82 registered (Branson304, Atesz792, bdcardinal, bbhero, Alfred_B, BeerCan, 11 invisible), 1979 Guests and 324 Spiders online.
58031 Members
66 Forums
249634 Topics
#2636472 - 05/25/12 11:17 PM 2005 Ford Focus 2.3 - lifetime air filter?
zanzabar Offline
Loc: NorCal
Looking into a used 2005 Focus ZX4 ST with 84k miles. Confused about the air filter design, does it really work?
Also what maintenance should I consider doing other than replacing all fluids, fuel filter, cabin air filter...etc?
2007 Volvo V70 (115k miles)
2014 Ford Focus (14k miles)
#2636489 - 05/25/12 11:49 PM Re: 2005 Ford Focus 2.3 - lifetime air filter? [Re: zanzabar]
jorton Offline
Loc: San Antonio, TX
2005 zx4 se
At 110,000 miles mine is still working I think.
Get the alignment checked. I had to put new upper control arms in the back. Handling was unsafe at highway speeds in the wet.
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
#2636501 - 05/26/12 12:07 AM Re: 2005 Ford Focus 2.3 - lifetime air filter? [Re: zanzabar]
bdcardinal Online   content
Loc: Santa Barbara, CA
Yes the air filter will last a long time. There should be a restriction gauge that will let you know when it needs changing. FWIW the only time I ever sell them is for vehicles that have been in an accident and the old filter is damaged.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
#2636503 - 05/26/12 12:10 AM Re: 2005 Ford Focus 2.3 - lifetime air filter? [Re: zanzabar]
gathermewool Offline
Loc: New England
The '05 ST I had a few years ago was a blast to drive, but had problems. Since new it would randomly (1/40 starts) take 4-5 seconds of cranking to start. The gear box was kind of clunky and, while stopped, would take some major finagling to get into 1st or reverse -really wasn't that big of a deal, but did cause some minor headaches here and there. Finally, just before I traded it I was getting random CEL's for airbag sensors.
I sold mine with ~46kmi on it, and never did figure out the air filter design. IIRC, it's the same engine and filter box from the Ranger, so if any 2.3L Duratec Ranger guys are out there, they can probably answer as well.
Sounds like you've got the new-to-you checklist down pat.
Edited by gathermewool (05/26/12 12:10 AM)
14 Forester XT
PUPPP + Subie blue filter
08 Civic LX (Auto)
VWB 5W-20 + Fram Ultra (3rd OFI)
#2638918 - 05/29/12 02:11 AM Re: 2005 Ford Focus 2.3 - lifetime air filter? [Re: zanzabar]
zanzabar Offline
Loc: NorCal
What other maintenance should I do? Clean the throttle body, MAF, PCV valve? I suppose I should just go search the Focus forum, I'm guessing there's an active one somewhere.
#2639094 - 05/29/12 09:53 AM Re: 2005 Ford Focus 2.3 - lifetime air filter? [Re: zanzabar]
Rand Offline
Loc: NE,Ohio
spend $$$ before purchase for a full inspection.
if you still want it you have ammo to lower the price.
if it comes back good you know its good.
2015 Forester I-Premium 6MT
#2644671 - 06/04/12 11:44 AM Re: 2005 Ford Focus 2.3 - lifetime air filter? [Re: zanzabar]
zanzabar Offline
Loc: NorCal
I do my own inspections.
In the process of updating the maintenance on this car. Everything looks pretty good on it, but the power steering fluid was dirtier than anything I've ever seen. I ended up doing a suck out the reservoir and refill with new fluid about 6 times (1 entire qt of Mercon ATF) and it finally started to have a red tint instead of looking like dark brown paint. Also, the throttle body was incredibly sticky, took sand paper to scrape off the buildup on it.
I'm still baffled by the intake design, it looks like the inlet is up on the cowl by the bottom of the drivers side of the windshield, then it runs down through the wheel well, up in front of the engine compartment to the air filter then across the top/front of the engine compartment into the throttle body and into the manifold. Lots of bends in there, is all that really necessary?
