A Gehl 5240 with a 4-cylinder Deutz engine. It is water cooled. The first UOA I did on this unit was at 500 hours which the OEM recommends. That one turned out great so took a sample at 750 hours w/o changing oil and then I changed the oil at 1000 hours. Using Service Pro or Shell Rimula 15w-40.
Hours 500, 772, 996
O Chn Y, N, Y
Iron 40, 80, 113
Chrm 1, 3, 4
Nick 0, 0, 1
Alum 3, 1, 2
Copp 0, 1, 1
Sili 3, 5, 4
Sod 5, 8, 5
Pot 0, 3, 0
Moly 30, 64, 69
Bor 7, 11, 10
Magn 806, 804, 774
Calc 1224, 1385, 1475
Phos 1064, 1044, 1107
Zinc 1234, 1317, 1313
Fuel Dil Soot .2%, .4%, .5%
Visc 14.8, 14.1, 14.4
TBN 3.36, 4.79, 5.18
Oxid 12, 13, 13
Nit 16, 18, 10
Somewhere after the first oil change, before I took the sample at 772 hours, the remote filter mount on the engine was leaking real bad and when I finally replaced the o-ring between it and the block, I hooked the pressure and return lines up backwards so I ran the engine for a little bit with no oil pressure. I think that is where the high iron came from but I think it is going to be ok because between 772 and 996 hours, the Iron seems to have evened out a little more. I think I'll take another sample at the next 750 hour interval and see how its doing then. I think 100 ppm Iron is going to be my condemnation limit for an oil change. Other than the Iron all other wear metals seemed excellent.
Hours 500, 772, 996
O Chn Y, N, Y
Iron 40, 80, 113
Chrm 1, 3, 4
Nick 0, 0, 1
Alum 3, 1, 2
Copp 0, 1, 1
Sili 3, 5, 4
Sod 5, 8, 5
Pot 0, 3, 0
Moly 30, 64, 69
Bor 7, 11, 10
Magn 806, 804, 774
Oxid 12, 13, 13
Nit 16, 18, 10
