I've been doing some roof repairs lately and found myself in (literally) a tight spot after cutting away some rotted decking to find this:
The load from the horizontal beam was only being supported by 1/2" ply! Oh my! Stupid builder strikes again. I needed to transfer this load to the large beam below as the roof truss does, but it was too tight to wedge a 2x4 in there, much less lift it. I cut a 5/12 wedge to assist, but the hammer-swinging-room was also limited.
Pondering over my options (need more hands for a long lever, too tight for a bottle jack, too little swing room to wedge it), I thought "Wait a minute...my car has a small jack that might work".
Volvo car jack to the rescue! I set it on top of the beam, gave her a couple of cranks and Viola! Enough room to slide the 2x4 into place
Then I slid my 5/12 wedge in place to increase the bearing area, removed the jack and tapped it into place:
Now this load is transfered to the beam where it belongs.
My lucky charm hidden in the trunk! Remember your car jack next time you need a lift in a tight spot.
