Dr. T,
"Why isn't the Neutra/Lube control good as a long term solution?"
They can be used as long-term cleaners in maintenance doses. When I want a quick clean (a flush), I use simply use them full strength. With Neutra or Lube Control, and with the valve cover(s) off, I can apply these directly to the varnished surfaces.
"Is it not as effective as auto-rx? Or are you counting on using the maintenance dose of auto-rx as a long-term solution?"
I was counting on the Auto-Rx as a maintenance dose after the initial Auto-RX 500 mile cleaning dose.
EDIT: What I have found in my vehicles, is that there is rusty layer underneath the varnish coating, and Lube Control will remove this rusty coating. I don't think varnish or lacquer on the valve stems or rockers harms anything, but when you want to clean the hydraulic lifters, you a need a fast acting cleaner (a flush), or a long-term, slow-acting cleaner. And of course, it doesn't hurt to clean the ring packs as well for better combustion sealing.
[ January 30, 2003, 10:57 PM: Message edited by: MolaKule ]
