I had about 450,000 miles on the original 7.3L in my F250 so I bought a used one with only about 230,000 off ebay and swapped it in. I changed mains & rods, front and rear main seals and a few other items. When I had the pan off, everything seemed to be in pretty good shape even though I suspect it may have been sitting awhile as a lot of the external components were starting to get a little rusted up. I used Schaeffer's 5w-40 because I like how much easier the engine starts in the cold ( even though this past winter was pretty mild ). I'm hoping I can go at least 20-30k miles. I'm using a Fleetguard LF9691 which uses full flow and bypass filtration. I did not change the oil here, only drew a sample.
Iron 25
Alum 2
Copp 6
Lead 13
Tin 4
Sili 42
Sod 11
Moly 327
Anti 275
Bor 4
Mag 762
Calc 1204
Bar 1
Phos 1028
Zinc 1199
Fuel Soot H2O TBN 5.59
Oxi 11
Nit 7
Vis 100c 13.1
They mentioned my Silicon being high but I think that is from all the RTV I used on the gaskets and seals I replaced. Lead and Iron are both a little higher than I'd like but do you think its something I should worry about or just continue on and do another UOA at 10,000 and see how things look?
Iron 25
Alum 2
Copp 6
Lead 13
Tin 4
Sili 42
Sod 11
Moly 327
Anti 275
Bor 4
Mag 762
Calc 1204
Bar 1
Phos 1028
Zinc 1199
Oxi 11
Nit 7
Vis 100c 13.1
