So just put in a used motor in this f-550 tow truck and cant get it to start. found out after taking the fuel filter off and watching the bowl while someone turns the key to the run position the fuel is aerating so fast its like a soda can foaming up with so many bubbles if you get what i mean. anyone have any input on this, we put on a new high pressure oil pump and have great oil pressure readings from the scan tool. we have no codes, and the thing will only run off starting fluid.no leaks in any of the fuel lines. its a 2001 f-550 7.3 auto pos any ideas what can cause the aeration? can it be the fuel filter housing itself? yes we are a professional shop but theres [censored] out there that kicks our asses too. and the service manager is just throwing parts at it, and im getting tired of working on the [censored] thing especially since im the fill in diesel tech right now
