Originally Posted By: JR
...I was looking at one of these motors to power a altinator to charge the bank of batteries powering my invertor. how do you like this little motor?
ken
Very nice engine. Starts with 1-2 pulls and is very smooth and quiet. Lots of power too. It never skips a beat, even spinning that monster multi-edged Ninja blade through thick stuff. The engine has a nice mellow tone to it.
Changing oil with one mounted on this particular mower was a PITA. At first I couldn't find the bottom drain, so it tipped it on it's side to drain the used oil out the dipstick tube. Only a few ounces came out.
I finally located the block drain underneath the belt guard under the deck. Had to remove the belt guard AND pop the drive belt off because oil would drain directly onto the belt no less.
As a result of tipping it with some fuel in the tank, the muffler loaded with fuel, which subsequently blew out of the muffler and all over the driveway on the 5-6 pulls it took to start the flooded engine afterwards!
Atleast I'll have a better procedure down for the next oil change.
Oh.. I'm going to try a pipe cutter on that filter to post some used filter pics. Unfortunately my filter cutter doesn't adjust small enough for this one.
Joel
