How come discount tire doesn't use jack stands?
by motor_oil_madman
07/23/16 09:41 PM
SAFETY ?: ramps in rear and jack stands in front
by SavagePatch
07/23/16 09:03 PM
Pennzoil ultra 5w30 back in stock at Walmart.com
by kohnen
07/23/16 08:37 PM
Homelite weedeater not getting fuel
by Drew99GT
07/23/16 08:26 PM
Stability issue on 2015 F250
by Donald
07/23/16 07:25 PM
2016 Tacoma 3.5L V6 4x4
by NavyVet88
07/23/16 07:10 PM
Question on 05 Nissan tranny w/120k
by NattyBoh
07/23/16 06:58 PM
Denso FTF oil filters
by mclasser
07/23/16 06:50 PM
03 rav4 2.0 awd only took 2qts of mtf?
by Cxserver
07/23/16 06:49 PM
Who manufactures Subaru motor oil
by machfive916
07/23/16 06:26 PM
all Valvoline 5 qt jug sale at Meijer 7/24 to 7/30
by a1mfw
07/23/16 06:25 PM
ice cream
by Rick in PA
07/23/16 05:49 PM
SonofJoe, Axle_Needle, discobob, KHump, Zounds
58573 Registered Users
99 registered (02s4audi, 4WD, 41 Plymouth, 2015_PSD, 440Magnum, 123Saab, 13 invisible), 1577 Guests and 12 Spiders online.
58573 Members
66 Forums
252172 Topics
Page 1 of 2 1 2 >
#2626177 - 05/14/12 08:03 AM How to clean cylinder head surfaces?
johnsmellsalot Offline
Loc: Texas
I fixed the head gasket on my 1999 Buick Century last year but now it's not sealing properly. Either I didn't clean it good enough or it was warped. The head bolts were also replaced.
I'm going to fix it again. Last time, I used Fel-Pro PermaDry but this time, I'm going to use the PermaTorque. They don't cost much more and they look better.
This time, I'm going to take the cylinder heads to a machine shop to make sure they're perfectly flat.
What should I use to clean the mating surfaces? The engine block is cast iron but the cylinder heads are aluminum.
1999 Buick Century 180,000 miles (first car)
2008 Chrysler PT Cruiser 70,000 miles
#2626187 - 05/14/12 08:13 AM Re: How to clean cylinder head surfaces? [Re: johnsmellsalot]
2009Edge Offline
Loc: Texas
A good putty knife or Scotch Bright should work.
#2626193 - 05/14/12 08:19 AM Re: How to clean cylinder head surfaces? [Re: johnsmellsalot]
46Harry Offline
Loc: hawthorne, Ca.
Be sure the head surface is flat, as there is no gasket that can compensate for a warped head. I always send heads to the machine shop for a resurface every time I remove one. I don't like to do a messy job twice. Also be sure that the bolt holes in the block are clean because dirty or corroded threads will give an inaccurate torque when the head is replaced. I use a gasket scraper and sometimes Scotch Bright to clean the deck of the block.
#2626221 - 05/14/12 09:10 AM Re: How to clean cylinder head surfaces? [Re: johnsmellsalot]
Jeff_in_VABch Offline
Loc: Virginia
The FelPro Perma-torque blue head gaskets are excellent sealing gaskets. They can overcome minor surcace irregularities better than most any other gasket.
When you take the head in, have it pressure tested also it you are having coolant leakage.
Also replace the head bolts again, as those are torque to yield bolts.
As far as cleaning and appearance, it must be perfectly spotless with no areas in question.
There may be useful info here:
http://www.fme-cat.com/Docs/1425.pdf
Interests - motorsports/engine building/tuning
Background - Performed work at refineries and several oil blending plants.
Occupation - Mech Engr
#2626237 - 05/14/12 09:23 AM Re: How to clean cylinder head surfaces? [Re: johnsmellsalot]
OVERKILL Offline
Loc: Ontario, Canada
Use Scotch-Brite on both surfaces, in an elliptical pattern (not side to side or in and out).
And make sure they are contaminant free, I usually use rubbing alcohol on a cotton cloth for that one.
02 Expedition
06 Charger R/T
14 Charger SRT-8
#2626331 - 05/14/12 11:08 AM Re: How to clean cylinder head surfaces? [Re: 46Harry]
Loc: Texas
How would you clean the bolt holes? I guess engine degreaser, pipe brush, and compressed air?
#2626341 - 05/14/12 11:17 AM Re: How to clean cylinder head surfaces? [Re: johnsmellsalot]
OVERKILL Offline
You are supposed to use a chase on the bolt holes. You can cheat and use a tap if you don't have one.
#2627003 - 05/14/12 09:53 PM Re: How to clean cylinder head surfaces? [Re: johnsmellsalot]
mechtech2 Offline
Loc: Chicago Area
Scotchbrite on an air or electric tool works great. Don't let debris get in the cylinders, oil, or coolant holes.
Heads can warp - have it checked. Blocks can too, but it is rare.
#2627811 - 05/15/12 10:07 PM Re: How to clean cylinder head surfaces? [Re: johnsmellsalot]
Loc: Texas
I tried scotch brite and a razor blade and they both worked pretty well.
I got my engine apart in about 4 hours today. I think that's pretty good considering that it took me almost a month the first time. LOL
Hopefully I get it right the second time and don't have to do it again. This is my first car and I don't plan on selling it anytime soon.
#2628311 - 05/16/12 02:14 PM Re: How to clean cylinder head surfaces? [Re: johnsmellsalot]
mechtech2 Offline
Loc: Chicago Area
Clean and check EVERY part. Bolts, tapped holes, surfaces... everything.
These extra steps will take another 1/2 hour/hour. But it makes the difference to get years of trouble free life [without later work or thinking about it].
#2628454 - 05/16/12 05:43 PM Re: How to clean cylinder head surfaces? [Re: mechtech2]
Loc: Texas
True...
#2628490 - 05/16/12 06:33 PM Re: How to clean cylinder head surfaces? [Re: OVERKILL]
artificialist Offline
Loc: Florida
I was told that using an old head bolt was enough.
2010 Lancer Ralliart Sportback
#2628491 - 05/16/12 06:35 PM Re: How to clean cylinder head surfaces? [Re: artificialist]
OVERKILL Offline
The problem with using an old bolt is that it doesn't have any "slots" in it to catch the dirt/contaminants and remove them from the threads, so it either grinds them into the threads (bad) or pushes them down into the hole further (bad).
A chase or tap, because it has slots, will remove the contaminants from the threads. You have to be careful with the tap though of course because it is designed to cut.
02 Expedition
06 Charger R/T
14 Charger SRT-8
#2628840 - 05/17/12 05:33 AM Re: How to clean cylinder head surfaces? [Re: johnsmellsalot]
Loc: Texas
These bolts have to be replaced because they are stretch head bolts. They stretch when you torque them down.
#2628924 - 05/17/12 08:33 AM Re: How to clean cylinder head surfaces? [Re: johnsmellsalot]
OVERKILL Offline
The term is "Torque To Yield" or TTY for short. And yes, they are a single use fastener as the name implies.
02 Expedition
06 Charger R/T
14 Charger SRT-8
Page 1 of 2 1 2 >
