The government as well as "AMERICAN Honda" decided not to waste perfectly good oil, by changing it out early due to break-in metals. It's what everyone is doing because of the "Green movement" and it kinda makes sense.
I personally drained the FF in my 07 Civic EX 1.8L @ 3k. I felt that by then, having been like 6 months of various driving conditions, the engine is FULLY broken in and good to go. I found A LOT of break-in metals in the catch pan during the OC. Glad i got it out. As you may have seen by the UOA reports the engine produces, they are below average, even though i'm doing extended intervals of 10k miles (going 2,000 miles past 0% Oil life, based on the MM (Maintenance Minder) system.
My 07 Civic Si got the FF drained @ 500 miles and replaced with Valvoline Maxlife, which at the time was loaded with moly. That engine also gave me fantastic operation for 4 years and 110,000 miles. I was also racing the car at the track quite often and drove it VERY aggressively on the street. Not a single issue expect minor oil consumption that Honda considers normal for the VTEC engines that are spinning @ 8,000+ RPM.
I'd personally get the FF out by 30-40% OL left. By then (approximately 5k miles) is long enough to have 90% of the break-in complete. It's best to get all that metal outta there! as i don't like the thought of metal shavings rubbing against the bearings, etc, etc.
The main reason to leave the break-in metals in the block long enough is to have the metallic bits act like sand paper and polish the internals of the block, smoothing out any manufacturing imperfections, etc, etc. After 3-5k miles, i personally believe it's pretty much done and anything else will get smoothed out in the next normal oil change interval based on the OLM System. Lets face it, today's engines are build MUCH better then 10 years ago, so the manufacturing process should result in less imperfections within the block.
Just my
P.S. the FF in my 98 Camry V6 was also dumped way early after only 100 miles and replaced with M1. 15 years later and currently sitting @ 220,000 miles, it runs amazing and returns higher then EPA rated gas mileage (even with all the Ethanol in the gas
). What more could you ask for?
