I just read Bob's info on the ISO-Syn process that makes Group III oils. Here is some of it:
Very good to excellent oxidation stability due to their high saturate content. Very good low volatility characteristics due to their high saturate content and the lack of lighter molecular ends.
BUT---
Hydrocracking produces highly sought after by
products such as naphtha and middle distillates.
Hydrocracked base oils do not contain any of the
natural sulfur antioxidants that are needed for
oxidation stability.
Hydrocracked base oils generally require the use of additional oxidation inhibitors.
Once the oxidation inhibitor additive package is depleted rapid oxidation will occur.
Uninhibited hydrocracked base oils will darken and form sludge when exposed to air and light.
Hydrocracked base oils have a low ability to solubilize the byproducts of oxidation.
This can result in the formation of sludge and rapid depletion of the oxidation inhibitors that are present in the lubricant formulation.
Hydrocracked base oils exhibit low solvency characteristics than other types of base oils.
Does Lube control add back the solvency needed to stop oxidation before it happens? Does it suspend blowby contamination? If so it must be important to continue adding it every thousand miles since it volatizes off in that time.
I'm no chemist. Thoughts???
[ December 21, 2002, 08:35 AM: Message edited by: jjbula ]
BUT---
