My daughter has a 2004 Mercury Sable with the DOHC engine. The transmission shifts smoothly when first started and for about 30 minutes. After warming up, and when starting from a dead stop, the tac will go up to about 2000 RPM's before the transmission shifts from 1st to 2nd. The shift is harsh, to say the least. Also, when in reverse, there is a knocking or bumping when the accelerator is depressed. If I put it in reverse and do not depress the accelerator, the car will slowly and smoothly move in reverse with no bumping.
When did it start? She is not sure >). The fluid is due for a change. It currently has Maxlife Dex/Merc which I put in about 60,000 miles ago (complete tranny flush, new filter, and cleaned pan). The car has about 175,000 miles on it.
The check-engine light is on, so I took it to O'Reily's to get a scan. Two codes came up. One was P0054 (Heated Oxygen Sensor) and the other was P0193 (Fuel Rail Resistance Sensor).
Any help would be greatly appreciated.
