Anybody have any opinions or experience with it? A lot of guys on the GM truck forums swear by it as a fuel system cleaner. TIA
Originally posted by dragboat: I have used it four times in the crankcase of our 92 Cavalier motor to remove Pennzoil varnish without any seal problems whatsoever.
Most interesed in the comment about the Pennzoil varnish. This has been floating around for a while that Pennzoil will leave a tint on the motor is this the case with the SL Pennzoil too?
I've used B12 in the crankcase in the past without any problems. Usually on the first oil change after I buy the car (I always buy used).quote:
Originally posted by mkosem:
can anyone else comment on B-12 in the crankcase?
There are detailed instructions on the can. I seem to remember it is half the can for the crankcase. I haven't tried it because I fear the ramifications of "fragging the oil" even for a few minutes. Maybe an even lower treat rate would be gentle enough.quote:
how often do you use it in the gas tank? Do you ever do followups in the crankcase? What kind of treatment regimine do you use in the crankcase. B-12 is **** potent.
--Matt
Found the 16 oz. can of Berryman B-12 Chemtool in my garage--quote:
hmm, I didn't remember seeing anything about that on the bottle. it'd be hard to dump 1/2 a bottle from an alu conainer.
--Matt
