I want to buy 1 case of oil for both cars. Nissan takes 5w30. My Ranger calls for 5w20 and has 12k miles on it. Any worries to be expected?
thanks
thanks
ARCOgraphite said:OP, the engine will be just fine on the slightly thicker 5w30. Besides, it specs 5w20 for emission purposes anyway. If it was up to Ford, they'd recommend a thicker oil for it.
No, it's 100% up to Ford and Ford spec's a 20wt oil because it is a more efficient lubricant than the heavier more shear prone 5W-30 grade. CAFE may have been the motivation to develop more fuel efficient motor oils but as one Ford engineer told me at the recent Toronto International Auto Show no sacrifices have been made in terms of engine durability. The 20wt oils used today are no lighter at operating temp's after extended service than the multi-grade 30wt oils of years past.
That said even the spec' 20wt oil is still too thick ever time the engine is started until the oil temp's get up to at least 80C.
