New - smoke detectors for house.
by bmwjohn
52 minutes 30 seconds ago
ProGauge PGO-4612 Oil Filter??
by andrewp1998
Today at 01:11 AM
Filter efficiency and diminishing returns
by ToadU
Today at 12:19 AM
Change PP after 1000 mi 6 month Short Winter Trips
by WillsYoda
Today at 12:00 AM
Tread Life & Curvy Roads
by Nick1994
Yesterday at 11:46 PM
What paper engine air filter do YOU recommend?
by Georgiey22
Yesterday at 11:20 PM
Power Steering Problems.......
by qwerty1234
Yesterday at 10:58 PM
CLR repair of completely blocked heater core/hose
by DoubleWasp
Yesterday at 10:55 PM
FS Ford racing Fiesta exhaust system
by mv6845
Yesterday at 10:27 PM
Inner Tie-rod removal
by Sawdusted
Yesterday at 09:54 PM
What's a good price for a 2013 4Runner?
by Gebo
Yesterday at 09:34 PM
Chrysler 42LE - avoid synthetic gear lubes
by Wampahoofus
Yesterday at 09:15 PM
Nazmorgul, bhans, truthtracer, Recreator, 18LateModelFan
56842 Registered Users
18 registered (dec219644, Bandito440, dan_erickson, chrisri, Astro14, 3 invisible), 417 Guests and 201 Spiders online.
56842 Members
66 Forums
244347 Topics
#261859 - 11/12/02 01:03 AM Racor Lube Oil Treatment
Anonymous
Unregistered
Racor, the filter company, has a line of additives. Most are for fuel, but they have one each for lube oil and for coolant.
Here's the info from the Lube Oil Treatment MSDS:
"TRADE NAME: RACOR LUBE OIL TREATMENT
DESCRIPTION: Lube oil additive containing zinc salt of dialkyl dithiophosphoric acid, borated
polyisobutenyl succinic anhydride nitrogen functionalized dispersant, magnesium and calcium alkylaryl detergents, solvent extracted mineral oil, alkyl amine and other components in a petroleum lubricating base stock,...."
I recognize the ZDTP...what will the other stuff do? They don't give amounts except <5% of the total volume.
Why add more ZDTP? Isn't there the correct amount in all good oils? Here's what Racor says about this product:
"Racor Lube Oil Treatment is a fluorocarbon additive which contains an advanced, highly effective polymer lubricant. It provides a superior thin coating to protect precision engine parts and does not contain PTFE which has been known to fall from suspension and clog precision engine components."
No, I'm not considering buying any, just curious.
Ken
#261860 - 11/12/02 05:16 AM Re: Racor Lube Oil Treatment
MolaKule Offline
Loc: Iowegia - USA
** Of course, as you correctly stated, this is a form of ZDDP.
, borated
** A multifunctional additive of Boron which acts as a dispersant to keep sludge and carbon suspended, and is also an AW and anti-corrosion additive.
** a detergent package to clean up engine parts and raise the TBN.
** probably just a good Group I base oil as a carrier.
alkyl amine and
** A surfactant and wetting agent to help spread the additive over metal parts.
** Maybe some more trace chemicals such as a defoaming agent and a rust preventative.
Not too bad; the problem is not knowing the amount of each additive. Too much of any one additive can conflict with other additives already in a formulated base oil. We call this a potential "additive clash."
Hope that helps.
#261861 - 11/12/02 06:18 AM Re: Racor Lube Oil Treatment
Anonymous
Unregistered
So it has an anti-wear agent, and dispersants and detergents, just like all good motor oils have.
I wonder why they sell the stuff, except to make money trading on their good name. I see a reason for products like Schaeffer's 132 or Auto-Rx, and no reason for this stuff.
Ken
#261862 - 11/12/02 06:44 PM Re: Racor Lube Oil Treatment
MolaKule Offline
Loc: Iowegia - USA
if I were running a trash oil from the local convienience store I might want to
"enhance" the oil a bit with this additive.
Any chance of sending in VOA of this stuff?
