Originally Posted By: antiqueshell
Something else that I wanted to mention...what about the rubber gaskets that are sealing the IACV to the TB..if a car is older perhaps a decade old is it a likelyhood that the TB solvent cleaner will damage the old rubber gaskets?
It depends on what's in your TB cleaner. Read the ingredients list. I'd be most concerned about acetone or other ketones. A touch of toluene or benzene might actually be good for them. Avoid anything with lutefisk in it. Ideally, keep the exposure time to a minimum. That means spraying with engine running, or clean with engine off, then start engine as soon as possible.
