Vehicle is a 98 Chrysler Town and Country AWD. It has the notoriously [censored] transmission. The original radiator was a 1 row with 2 transmission coolers. My radiator plastic end tank popped a hole in it so the one I am getting is a 2 row with 2 transmission coolers. Apparently the original wasn't good enough (heated up too much)and Chrysler went with a 1 internal transmission 1 external transmission cooler setup.
I prefer to work with my old setup and make the most of it since it is a bolt in affair.
Any suggestions on which coolant to use and what percent water/coolant in this case. Is there anything that won't destroy the plastic end tanks? I couldn't find an all aluminum radiator or I would have bought that.
Don't want to get too exotic with coolant. If I can't get it locally then I don't want it.
Thanks
Thanks
