Hello all.
Was finally allowed to register, have a few questions.
Changed the oil on our 07 e320 bluetec at 101k miles.
Done oil changes at 5k its entire life, as well as all other recommended services, at our local independent.
Always using the correct oil, mobil 1 oil.
Comments:
We found nice low wear on this first sample form your e320- maybe a bit too low. Our universal averages show typical wear from this type of engine after 6200 miles of oil use. Your oil run wasnt quite as long, so lower wear is to be expected but your wear is far enough below average that its possible the 4.5% fuel may have diluted the sample. It definitely brought the viscosity down into the 5w20 range. The fuel doesn't seem to be causing extra wear, but if the oil level is rising on the dipstick, you may have a fuel system issue. The TBN was okay at 3.7
Doing searches around other forums, people claim that GM trucks allow up to 5% as normal in their diesel vehicles.
Thats GM, not mercedes, nothing against GM, but different companies have different allowed values.
Any input?
Comments:
Any input?
