Any input on parts change out on a t-belt change on a low mileage "99 Avalon V6 1MZ-FE w/23,000 miles? No leaks or other issues, including a quick look at the tensioner. Original factory fill on the coolant, but it looks very clean. Usually I replace the t-belt, bearings and tensioner ,water pump seals on t-belt jobs when it is mileage wear out. Any info on age wear out on this motor? Some feedback I have is just to replace the belt if all else looks OK .
