Yes I replaced the rod bearings. I did this before the Auto-RX because I had to start using the car immediately for the long daily commute. The knock was a cracked rod bearing on cylinder 5. Cylinder 3,5,6 all had badly worn bearings. Good thing I checked it.quote:
Originally posted by MolaKule:
showz123,
Did you go ahead and replace the lower bearings? Did the replacement of the bearings take the lower-end knock out of the engine?
