Fellas, I need some help troubleshooting:
2002 Toyota Camry, 4cyl, Automatic, USA model.
A CEL code popped up the other day for "Bank 1 A/F Sensor." I went ahead and replaced the pre-cat O2 with a new sensor. the battery was re-connected, and I took it for a drive.
At first, the car drove nicely with no codes. Then I noticed that as the engine warmed up, the idle became very low. There is also hesitation when accelerating from a stop. The idle eventually got so low that it causes the car to stall out.
I've read that it is typical for this to happen after disconnecting the battery, but it has taken a little too long for the car to re-learn itself. I've been through about 4 or 5 driving cycles so far, and 20 miles worth of driving.
Any ideas on what might be going on? Thanks.
