Originally Posted By: Cujet
I deal with CIC (corrosion inhibiting compounds) daily.
In the past, they were often thinned with a chlorinated, fast evaporating solvent. Today, there are other types of carriers. From MEK to butane, kerosene and everything in between.
LPS-3 has been an aviation standard for years. However, it is not the best.
Par-al-Ketone (made by Black Bear) is very much like cosmoline, it's thick, gooey, dries to a tough waxy coating. It can be thinned with MEK (or even Avgas) for applications where it needs to "creep" into tight places. Such as between layers of sheet metal. It's also very inexpensive.
My personal favorite is AV-30, which used to be made by Dinatrol, but now is made by another brand. It's thin, sprayable, and dries to a tack free coating that is incredibly effective. It's thinable with MEK. The product is very expensive.
An easy solution is Boeshield. It's effective and clear.
But, if you want a chain lube, I suggest Bel-Ray "super clean" chain lube applied normally, then add a thin oil such as GT-85 (slightly thicker than WD-40)
Or you could simply melt some wax, mix it with small quantities of your favorite synthetic oil and then blend in some thinner such as MEK.
Thanks for the info. I think I'm finally getting enough info to move forward. Really, I'm trying to make my own stuff. Call if for fun....or whatever, it's just some experimenting. Yes, I know I can buy anything under the sun. I just don't want to.
What I'm starting to see is that things that go on wet but end up more waxy (to some degree)...are just a petroleum carrier solvent and a dissolved heavy paraffinic. The lighter carrier evaporates, leaving behind the waxy coating. I think you've helped me solve the carrier solvent portion. What I'm thinking is that this "basic" type of setup (I'm sure there's more too it in many cases) should get me anywhere from something similar to LPS on one end, to cosmoline on the other end of the spectrum. At least that's what I'm thinking.
I will try disolving paraffin in MEK (which should evaporate pretty quickly) and see what that gets me as a start on the petroleum solvent carrier and heavy paraffinic mixture experiments. Xylne will dissolve paraffin, but it doesn't evaporate fast enough (I don't think).
thanks!
