Oil Report for my 1997 Mercury Sable 12 valve.
Blackstone: No serious complaints to file in this sample from your Sable. The longer oil run did result in mildly higher wear, but none of these levels are cautionary. Lead was highlighted last time and it increased slightly, but keep in mind it's only four ppm higher than universal averages and that's not enough to get worked up over. You might want to check the air filtration systems for any leaks or cracks due to silicon. It can show abrasive dirt, but can also be from harmless sealants. The TBN was 1.6 showing a little additive left. Nice report overall at 121,513.
Aluminum 5
Chromium 2
Iron 19
Copper 7
Lead 9
Tin 2
Molybdenum 134
Nickel 1
Manganese 1
Silver 0
Titanium 1
Potassium 2
Boron 8
Silicon 28
Sodium 340
Calcium 2062
Magnesium 12
Phosphorus 664
Zinc 791
SUS Visc 59.7
TBN 1.6
Could a vacuum leak be cause the elevated silicon levels?
Aluminum 5
Chromium 2
Iron 19
Copper 7
Lead 9
Tin 2
Molybdenum 134
Nickel 1
Manganese 1
Silver 0
Titanium 1
Potassium 2
Boron 8
Silicon 28
Sodium 340
Calcium 2062
Magnesium 12
Phosphorus 664
Zinc 791
SUS Visc 59.7
TBN 1.6
