1 Man Brake Bleed
Check out the phoenix systems brake bleeder. From everything I have read, this is the best way to do it since the air bubbles want to go up instead of trying to force them down. This introduced fluid from the calipers and the air bubbles escape from the master cylinder.
Once again, there is no need to submerge a line in fluid with any PROPER bleeding technique.
NONE.
Yes, I have heard this all my life and have done it in the past.
NONE.
You're correct but it adds a bit of insurance for the guys who aren't a pro doing this every day.
NONE.
It's for people like me... I need all the assurance/insurance I can get.
With a two man pedal pumping type brake bleed, it really helps if the brake guy knows up from down [when bleeder boy requests either].
