Acronyms used at BITOG.
Maybe remove the Lucas reference from UCL? I think of that as more a class of additives (granted Lucas is probably the most common UCL, but there's also Restore and DuraLube etc). My 2c.
Great list! I had to read BITOG for a while before I figured out some of these.
A few more ...
PAO = polyalphaolefins
VII = Viscosity Index Improver
ZDDP = Zinc dialkyl dithio phosphate - main use as anti-wear additive
NOACK = a test procedure for measuring volatility
pp = pour point
TBN = Total Base Number -- oil analysis
TAN = Total Acid Number -- oil analysis
PPD = Pour Point Depressant - additive that retards wax crystallization - lowers the pour point
EP = extreme pressure additive
TOST - Turbine Oil Stability Test ASTM D-943
RPVOT = Rotating Pressure Vessel Oxidation Test
MSDS = Material Safety Data Sheet
PDS = Product data sheet
cP = Centipoise - a unit of absolute viscosity
cSt = Centistoke - a standard unit of kinematic viscosity
KV = Kinematic viscosity
CAFE - Corporate Average Fuel Economy
POE = Polyolester
Corrections ...
SLOB=Street Legal Octane Booster
should be ... SLOB = Street Legal Oil Boost
CP=Conoco Philips (makers of MotorCraft/Kendall/Philips66 and others)
should be ... COP = ConocoPhillips (makers of MotorCraft/Kendall/Philips66 and others)
IOLM: Intelligent oil life monitor. As opposed to Ford's original, simple mileage counter.
Originally Posted By: wally6934
If the group would proof read for errors and list any I might have missed, I this this would make a good sticky.
PEA = polyether amine, the goods in terms of FSC (fuel system cleaners) such as Redline si1 and Regane HM (High Mileage).
And also the bolded word for errors :p
The following will be added to the acronym list. Should i remove the
"SLOB = Street Legal Octane Booster" I do find it talked about on the internet.
SLOB = Street Legal Oil Boost by CD-2 and others, high levels of Calcium, Phosporus, and zink
UCL = Upper Cylinder Lubricant from Lucas, Restore, DuraLube, and others, a gasoline additive
PAO = PolyAlphaOlefins
ZDDP = Zinc Dialkyl Dithio Phosphate - main use as an anti-wear additive
NOACK = A volatility test that determines the evaporation loss of lubricants in high-temperature service.
pp = pour point
PPD = pour point Depressant - additive that retards wax crystallization - lowers the pour point
EP = Extreme Pressure additive
TOST - Turbine Oil Stability Test, ASTM D-943
PDS = Product Data Sheet
cP = centiPoise - a unit of absolute viscosity
cSt = centistoke - a standard unit of kinematic viscosity
CAFE = Corporate Average Fuel Economy
POE = Polyolester
IOLM = Intelligent Oil Life Monitor. As opposed to Ford's original, simple mileage counter.
GM = General Motors
EOS = Engine Oil Supplement by GM, Engine Assembly Prelube for piston and lifter scuffing as well as the camshaft.
PEA = PolyEther Amine, the active ingeadiant in fuel system cleaners such as Techron, Redline, Sil and Regane HM
I did not add
"GC = ... sometimes referred to GREEN Castrol because it was originally was green."
Because the GC line was already the longest and this would take it to 2 lines. Formating would become a problem
Latest list with all editions and spell checks.
AAP = Advance Auto Parts
ADBV = Anti Drain Back Valve
AF = Air Filter
API = American Petroleum Institute
API-TC = 2 cycle, air cooled engine oil specification
AW = Anti-Wear
AZ = Auto Zone
BBC = Big Block Chevy
BITOG = Bob Is The Oil Guy
BOGO = Buy One Get One Free
BP = British Petroleum
CEB = Castrol Edge Black bottle/with Syntec
CEG = Castrol Edge Gold
CEL = Check Engine Light
COF = Coefficient Of Friction
CRD = Common Rail Diesel
CSK = Cold Start Knock
CSK = Checker, Schuck's, and Kragen, auto parts stores now called O'Reilly's
Dino = Regular/conventional Motor Oil(s)
EP = Extreme Pressure additive, reduces ware
FAR = Free After Rebate
FF = Factory Fill
FF = First Fill
FLAPS = Favorite Local Auto Parts Store
FS = Formula Shell
Fuchs = European MFG of quality lubricants
G-oil = GREEN Motor Oil, from Green Earth Technologies
GC = German Castrol...Castrol Syntec, It will say "Made in Germany" on the back. New name, changed to Castrol Edge
GM = General Motors
HDEO = Heavy Duty Engine Oil
HDMO = Heavy Duty Motor Oil
HM/HMO = High Mileage/High Mileage Oils
HTHS = High Temperature, High Shear rate viscosity
IDK = I Don't Know
IDR = I Don't Recall
IIRC = If I Recall/Remember Correctly
ISO = European Standards
J300 = SAE engine oil viscosity classification standard
JASCO = Japanese Standards
KV = Kinematic viscosity, is the ratio of absolute or dynamic viscosity to density
LIM = Lower Intake Manifold
LOS = Lucas Oil Stabilizer
M1 AFE = Advanced Fuel Economy
M1 EP = Extended Performance
M1 ESP = Emission System Protection full synthetic diesel oil
M1 = Mobil 1, all Mobil 1 oils are full synthetic
M5K = Mobile 5000 mile Dino oil, discontinued
MC = MotorCraft...Not Mobil Clean
MM = Maintenance Minder
MMO = Marvel Mystery Oil
MOA = Motor Oil Additive
MOFT = Minimum Oil Film Thickness
MOS2 = Molybdenum Disulphide
MS5k = Mobil Super 5000
NMMATCW3 = National Marine Manufacturers Association
OBD = On-Board Diagnostics/engine codes
OCD = Obsessive Compulsive Disorder
OCI = Oil Change Interval
OCOD = Orange Can of Death
OD = Over Dose
OEM = Original Equipment Manufacturer
OLM = Oil Life Monitor
OP= Original Poster
OP = Oil Pressure
OPE = Outdoor Power Equipment
O'R = O'Reilly Auto Parts
OT = Oil Temperature
OUO = Oil of Unknown Origin
P1 = Pure One oil filter
PAO = PolyAlphaOlefins, , a base stock for oils
PEA = PolyEther Amine, the active ingredient in fuel system cleaners such as Techron, Redline, Sil and Regane HM
POE = Polyol Esters, a base stock for oils
PC = Petro Canada
PCMO = Passenger Car Motor Oil
PO = Previous Owner
PP = Pennzoil Platinum
pp = pour point, is the lowest temperature at which a liquid becomes semi solid and loses its flow characteristics
PU = Pennzoil Ultra
PYB = Pennzoil Yellow Bottle
QSDefy = Quaker State Defy
QSED = Quaker State Extended Durability
QSGB = Quaker State Green Bottle
QSUD = Quaker State Ultimate Durability
RL = Red Line oil
RP = Royal Purple
SBC = Small Block Chevy
SLOB = Street Legal Oil Boost by CD-2 and others, high levels of Calcium, Phosphorus, and zinc
SOPUS = Shell Oil Products United States
ST/STD = SuperTech/SuperTech Dino
STS = Super Tech Synthetic
TC = Spec for low ash 2 cycle air cooled engine oil
TCW3 = Spec for no ash 2 cycle liquid cooled engine oil, W means Water cooled
TOST = Turbine Oil Stability Test, ASTM D-943
UIM = Upper Intake Manifold
UOA = Used Oil Analysis
US0 = use search option
VDB = Valvoline DuraBlend
VI = Viscosity Index, an arbitrary measure for the change of viscosity with temperature
VII = Viscosity Index Improver, these compounds make it possible to make multigrade oils
VML/ML = Valvoline MaxLife/MaxLife
VOA = Virgin Oil Analysis
VSET = Valvoline Synpower Professional Engine Treatment
VSOT = Valvoline synpower oil treatment 15 oz VSOT (Valvoline Synthetic Oil Treatment)
VWB = Valvoline White Bottle
WPP = Warren Petroleum Products
XOM = Exxon Mobil
YMMV = Your Milage May Vary
Don't forget
DKDC-Don't know, Don't care
Thank you for compiling this list. Here are a few more:
ATF = Automatic Transmission Fluid
MTF = Manual Transmission Fluid
PS = Power Steering (system)
PSF = Power Steering Fluid
VMLNG = Valvoline MaxLife NextGen
VNG = Valvoline NextGen
VSP = Valvoline SynPower
that's a big list. I usually only see about 9-10 of those being used on the daily basis.
Good job guys
One more:
RLI = Renewable Lubricants, Inc.
Great list, BTW. I actually didn't know what BOGO was until now, thanks for posting this! :)
Good job everybody, I have some
HDS - Havoline Deposit Shield
MS - Mobil Super (some use it)
CQ - Carquest
QS - Quaker State (anything)
PZ - Pennzoil (anything)
HM - High Mileage (anything)
DW - Driveworks (filters)
MG - Microgard (filters)
GLO - Gear Lube Oil
and I also say PZHM (Pennzoil High Mileage)
and pretty universal sayings,
IMO - in my opinion
IMHO - in my humble/honest opinion
IRL - in real life
