pretty true.
have a look at the ring-gear of a straigh 6, and you will see that the starter engages in 3 general areas.
The Mirlees straight 8 diesel at work has only 5 cylinders equiped to start, as that's as many (probably more) than are required to ensure a start under any given crank position.
