JHZR2
Staff member
Hi,
I have a three-way switch setup on the stairs to my basement which lets me turn on the basement lights from either the landing (which has an entry door), or the top. It works well, unless youre carrying a load, in which case it can be more of a hassle. We are re-doing some parts of the stairway, so I was thinking of putting in a motion sensor switch just at one of the locations, so it can scan for motion. I dont see a need for two, as the switches are in close proximity.
The Leviton ODS10-IAW model is US made, so it is what I'd go with. They offer a Mexican and Chinese variant which I am boycotting.
The instructions can be seen here:
www.leviton.com/OA_HTML/ibcGetAttachment...amp;appName=IBE
For convenience, the wiring diagram is as follows:
So it shows either a single motion sensor switch wired to control the load, or two wired together in a three-way fashion, but they are two identical switches.
What if I want one motion sensor switch and one standard, old fashioned three-way switch which is already wired into the circuit? Will there be issues with this?
Thanks!
Thanks!
