Just an interesting question
by southernjeeper
05/26/16 01:52 AM
Value power Walmart battery acid flying out
by bbhero
05/26/16 12:44 AM
Leased 2013 Ford Suv With19,882 Miles Original Oil
by crazyoildude
05/25/16 10:35 PM
Steak-House Burgers
by sleddriver
05/25/16 09:53 PM
Got into an accident.
by bdcardinal
05/25/16 09:42 PM
Its coming here more and more
by CourierDriver
05/25/16 08:40 PM
Interpreting oil pressure vs engine RPM
by Emperors6
05/25/16 08:39 PM
$4 Fram Ultra - Blain's F&F
by Poohbah
05/25/16 08:21 PM
Toolbox - Pliers
by greasegunn
05/25/16 08:09 PM
ProSelect Oil Filter????
by qwerty1234
05/25/16 08:05 PM
Completing your 80% lower with a CNC Machine
by Merkava_4
05/25/16 07:33 PM
Motor oil Sale
by GuinnessGuy
05/25/16 07:26 PM
jerryg, 1971tr350, Mak712, Lex4TDI4Life, cdub76
57988 Registered Users
27 registered (asand1, Burt, Bandito440, Astro14, 4 invisible), 583 Guests and 283 Spiders online.
57988 Members
66 Forums
249411 Topics
Page 4 of 7 < 1 2 3 4 5 6 7 >
#2776397 - 10/18/12 11:35 AM Re: Acronyms used at BITOG, make me a sticky [Re: wally6934]
Kuato Offline
Loc: In transit...
I've seen BOF....what's that one?
Your oil's condition is pure speculation until you get a UOA.
13 F150, 5.0, 48k mi
04 Wrangler, 2.4, 197k mi
Amsoil user, moving to Schaeffer soon.
#2777189 - 10/19/12 08:26 AM Re: Acronyms used at BITOG, make me a sticky [Re: wally6934]
Kuato Offline
Loc: In transit...
Body On Frame.
#2783485 - 10/25/12 02:36 PM Re: Acronyms used at BITOG, make me a sticky [Re: wally6934]
alzsynthetics10 Offline
Loc: Utah, USA
looking over this list make me wonder how many of these Acronyms are really used by used by anyone. It looks like a lot of them are just made up as the writer went along. How about some "real" Acronyms, like:
ANSI - American National Standards Institute
ATF - Automatic transmission fluid
BF3 - Break Fluid Dot 3
BF4 - Break Fluid Dot 4
OLMS - Oil life monitoring system
ISO - International Organization of Standardization
PSF - Power steering fluid
XOD - Extended oil drain
SAE - Society of Automotive Engineering, and
OD - Over due (Over Dose, sounds too much like we are into something that isn't car related.
Cheers to all; have a great day!
Edited by alzsynthetics10 (10/25/12 02:39 PM)
Al'z Lube Shack
#2814259 - 11/26/12 12:44 AM Re: Acronyms used at BITOG, make me a sticky [Re: wally6934]
HemiEnvy Offline
Loc: Littleton, Colorado, USA
Okay, I'll bite..what is the Orange Can of Death?
HemiEnvy
#2814484 - 11/26/12 09:14 AM Re: Acronyms used at BITOG, make me a sticky [Re: wally6934]
SteveSRT8 Online   content
Loc: Sunny Florida
^^^FRAM!
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
#2893225 - 02/02/13 10:18 PM Re: Acronyms used at BITOG, make me a sticky [Re: wally6934]
Durangoboy Offline
Loc: Kansas
MWEW
My worthless ex wife
#2904387 - 02/12/13 08:42 PM Re: Acronyms used at BITOG, make me a sticky [Re: wally6934]
Icecube Offline
Loc: Canada
Okay. I must be blind but I don't see a definition for "moly" and I am afraid I don't know what it is. Can someone explain?
Thanks
#2904436 - 02/12/13 09:16 PM Re: Acronyms used at BITOG, make me a sticky [Re: Icecube]
Pablo Offline
Loc: Duvall WA - Pacific NW USA
Thanks
Definition?
"Moly" is a slang/abbreviation for Molybdenum (Mo) an element.
http://en.wikipedia.org/wiki/Molybdenum
In use here it's short for one of the oil soluble additive compounds, which are Mo and typically an organic/thio component. A multifunctional additive.
#2908157 - 02/16/13 08:05 AM Re: Acronyms used at BITOG, make me a sticky [Re: wally6934]
FamilyBuggy Offline
Loc: USA
I noticed SN is not listed. What does it mean?
#2911878 - 02/19/13 07:18 AM Re: Acronyms used at BITOG, make me a sticky [Re: wally6934]
bigt61 Offline
Loc: Virginia
CCS = Cold-Cranking Simulator
Had to look this up..
Q: How Is a 0w30 oil with a ccs viscosity cP (D5293) @-35 degrees celcius with a rating of 3808 compare to one measured @ -20 with a ccs score of 5621?
"MotorOilEvaluator says:
The lower the temperature that an oil is tested at, the higher itís CCS viscosity number will be, and a 5 degree difference can actually have a pretty significant effect on that number.
Thus, IF the numbers you provided in your question above are correct and not typos, the first oil is CONSIDERABLY better than the second, at least in regards to cold weather cranking. This is because, if the first oil had been tested at -20 degrees vs -35 degrees, itís CCS value would actually be much lower than it already is at 3808.
Since the second oil is already considerably higher at 5621, the gap between the two would likely be even greater if both oils were tested at the same temperature.
That being said, be careful with this. It is not uncommon for spec sheets to have typos. A 0w30 oil MUST be tested at -35 degrees and achieve a CCS value of LESS than 6200 cP in order to be classified as a 0w oil. So, itís possible that your 0w30 oil which indicates it was tested at -20, may actually have been tested at the required -35, but the PDS was typed up incorrectly.
Either way, even if the second oil was tested at -35, if the 5621 cP number is correct, then, the first oil is still better in cold temps.
Of course, that doesnít say anything about itís performance in hot temps or other stressful conditions Ė just cold temps."
Edited by bigt61 (02/19/13 07:19 AM)
92 Suburban 2500 7.4L 58k M1_5w30 5yr OCI
99 Olds Aurora 4.0L 91K M1_5w30 5yr OCI
13 Dodge Dart 2.0L 29k PP 0w20 OLM OCI
70 Camaro 5.7L 59k
#2921718 - 02/26/13 11:03 PM Re: Acronyms used at BITOG, make me a sticky [Re: wally6934]
Brybo86 Offline
Loc: Chicago, IL
Tgmo?
08 Honda Accord EX-L 2.4L RP 0w20 116k
01 Kymco People 50
95 Lexus LS400 M1 AFE 0w30 178k
95 Yamaha Jog
86 Kawasaki 454Ltd Valvoline 20w50 18k
#2921720 - 02/26/13 11:04 PM Re: Acronyms used at BITOG, make me a sticky [Re: Brybo86]
Clevy Offline
Loc: Saskatoon canada
Originally Posted By: Brybo86
Tgmo?
Toyota genuine motor oil
2006 Charger RT
Miles x 2 per oil filter
#2931518 - 03/07/13 12:59 PM Re: Acronyms used at BITOG, make me a sticky [Re: FamilyBuggy]
GC4lunch Offline
Loc: Atop a hill above Portland, Or...
The current (most recent) American oil specification, which supplanted SM, which previously supplanted SL, etc.
But what is DI?
#2931545 - 03/07/13 01:37 PM Re: Acronyms used at BITOG, make me a sticky [Re: wally6934]
Loc: Sunny Florida
DI = Direct Injection
#2931835 - 03/07/13 06:40 PM Re: Acronyms used at BITOG, make me a sticky [Re: wally6934]
KeMBro2012 Offline
Loc: California
I might get a short vacation for this but it's totally worth it if at least a few of you laugh.
AABSDNF - Advice Approved By Skyship, Do Not Follow
