Non-directional performance winter tires 205/65-15
by slacktide_bitog
08/25/16 06:14 PM
Is there a market for a used tool box? w/Pics
by Jimmy9190
08/25/16 05:18 PM
Review of Sangrean Weather Radio CL-100
by chiefsfan1
08/25/16 05:18 PM
Round holes AND louvers! Oh the humanity!
by Nick1994
08/25/16 04:20 PM
Should I change the oil when changing spark plugs?
by THafeez
08/25/16 04:08 PM
Maxima synthetic oil
by gman2304
08/25/16 04:02 PM
Mobil vs. Castrol: Battle of the Walmart 0W-40s
by 1JZ_E46
08/25/16 03:58 PM
Need advice for older car burning too much oil
by Car_Careguy
08/25/16 03:29 PM
Camaro 2.0T review by subaruwrxfan
by wemay
08/25/16 03:18 PM
Dryer Duct Boosters?
by 2015_PSD
08/25/16 03:02 PM
some strange lawsuits against fast food franchises
by John_Conrad
08/25/16 02:40 PM
Rotella T5 10W-30 in Chevy Z71
by RHALL
08/25/16 02:20 PM
ryaneirich, Gabe78, taters, Louis_Desbiens, Burk
58918 Registered Users
99 registered (123Saab, 09_GXP, 2010Civic, 1JZ_E46, 02s4audi, 10 invisible), 1515 Guests and 5 Spiders online.
58918 Members
66 Forums
253552 Topics
Page 3 of 7 < 1 2 3 4 5 6 7 >
#2610295 - 04/26/12 11:01 AM Re: Acronyms used at BITOG, make me a sticky [Re: Chevys_n_Hawgs]
wally6934 Offline
Loc: Wi
Latest list with all editions and spell checks.
AAP = Advance Auto Parts
ADBV = Anti Drain Back Valve
AF = Air Filter
API = American Petroleum Institute
API-TC = 2 cycle, air cooled engine oil specification
AW = Anti-Wear
AZ = Auto Zone
BBC = Big Block Chevy
BITOG = Bob Is The Oil Guy
BOGO = Buy One Get One Free
BP = British Petroleum
CAFE = Corporate Average Fuel Economy
CEB = Castrol Edge Black bottle/with Syntec
CEG = Castrol Edge Gold
CEL = Check Engine Light
COF = Coefficient Of Friction
COP = ConocoPhillips (makers of MotorCraft/Kendall/Philips66 and others)
cP = centiPoise - a unit of absolute viscosity
CRD = Common Rail Diesel
CSK = Cold Start Knock
CSK = Checker, Schuck's, and Kragen, auto parts stores now called O'Reilly's
cSt = centistoke - a standard unit of kinematic viscosity
Dino = Regular/conventional Motor Oil(s)
EOS = Engine Oil Supplement by GM, Engine Assembly Prelube for piston and lifter scuffing as well as the camshaft
EP = Extreme Pressure additive, reduces ware
FAR = Free After Rebate
FF = Factory Fill
FF = First Fill
FLAPS = Favorite Local Auto Parts Store
FS = Formula Shell
Fuchs = European MFG of quality lubricants
G-oil = GREEN Motor Oil, from Green Earth Technologies
GC = German Castrol...Castrol Syntec, It will say "Made in Germany" on the back. New name, changed to Castrol Edge
GM = General Motors
HDEO = Heavy Duty Engine Oil
HDMO = Heavy Duty Motor Oil
HM/HMO = High Mileage/High Mileage Oils
HTHS = High Temperature, High Shear rate viscosity
IDK = I Don't Know
IDR = I Don't Recall
IIRC = If I Recall/Remember Correctly
IOLM = Intelligent Oil Life Monitor. As opposed to Ford's original, simple mileage counter
ISO = European Standards
J300 = SAE engine oil viscosity classification standard
JASCO = Japanese Standards
KV = Kinematic viscosity, is the ratio of absolute or dynamic viscosity to density
LIM = Lower Intake Manifold
LOS = Lucas Oil Stabilizer
M1 AFE = Advanced Fuel Economy
M1 EP = Extended Performance
M1 ESP = Emission System Protection full synthetic diesel oil
M1 = Mobil 1, all Mobil 1 oils are full synthetic
M5K = Mobile 5000 mile Dino oil, discontinued
MC = MotorCraft...Not Mobil Clean
MM = Maintenance Minder
MMO = Marvel Mystery Oil
MOA = Motor Oil Additive
MOFT = Minimum Oil Film Thickness
MOS2 = Molybdenum Disulphide
MS5k = Mobil Super 5000
NMMATCW3 = National Marine Manufacturers Association
MSDS = Material Safety Data Sheet
NOACK = A volatility test that determines the evaporation loss of lubricants in high-temperature service
OBD = On-Board Diagnostics/engine codes
OCD = Obsessive Compulsive Disorder
OCI = Oil Change Interval
OCOD = Orange Can of Death
OD = Over Dose
OEM = Original Equipment Manufacturer
OLM = Oil Life Monitor
OP= Original Poster
OP = Oil Pressure
OPE = Outdoor Power Equipment
O'R = O'Reilly Auto Parts
OT = Oil Temperature
OUO = Oil of Unknown Origin
P1 = Pure One oil filter
PAO = PolyAlphaOlefins, , a base stock for oils
PEA = PolyEther Amine, the active ingredient in fuel system cleaners such as Techron, Redline, Sil and Regane HM
POE = Polyol Esters, a base stock for oils
PC = Petro Canada
PCMO = Passenger Car Motor Oil
PDS = Product Data Sheet
PO = Previous Owner
PP = Pennzoil Platinum
pp = pour point, is the lowest temperature at which a liquid becomes semi solid and loses its flow characteristics
PPD = pour point Depressant - additive that retards wax crystallization - lowers the pour point
PU = Pennzoil Ultra
PYB = Pennzoil Yellow Bottle
QSDefy = Quaker State Defy
QSED = Quaker State Extended Durability
QSGB = Quaker State Green Bottle
QSUD = Quaker State Ultimate Durability
RL = Red Line oil
RP = Royal Purple
RPVOT = Rotating Pressure Vessel Oxidation Test
SBC = Small Block Chevy
SLOB = Street Legal Oil Boost by CD-2 and others, high levels of Calcium, Phosphorus, and zinc
SLOB = Street Legal Octane Booster
SOPUS = Shell Oil Products United States
ST/STD = SuperTech/SuperTech Dino
STS = Super Tech Synthetic
TAN = Total Acid Number -- oil analysis
TBN = Total Base Number -- oil analysis
TC = Spec for low ash 2 cycle air cooled engine oil
TCW3 = Spec for no ash 2 cycle liquid cooled engine oil, W means Water cooled
TOST = Turbine Oil Stability Test, ASTM D-943
UCL = Upper Cylinder Lubricant from Lucas, Restore, DuraLube, and others, a gasoline additive
UIM = Upper Intake Manifold
UOA = Used Oil Analysis
US0 = use search option
VDB = Valvoline DuraBlend
VI = Viscosity Index, an arbitrary measure for the change of viscosity with temperature
VII = Viscosity Index Improver, these compounds make it possible to make multigrade oils
VML/ML = Valvoline MaxLife/MaxLife
VOA = Virgin Oil Analysis
VSET = Valvoline Synpower Professional Engine Treatment
VSOT = Valvoline synpower oil treatment 15 oz VSOT (Valvoline Synthetic Oil Treatment)
VWB = Valvoline White Bottle
WPP = Warren Petroleum Products
XOM = Exxon Mobil
YMMV = Your Milage May Vary
ZDDP = Zinc Dialkyl Dithio Phosphate - main use as an anti-wear additive
#2611670 - 04/27/12 07:45 PM Re: Acronyms used at BITOG, make me a sticky [Re: wally6934]
toneydoc Offline
Loc: War Eagle
Don't forget
DKDC-Don't know, Don't care banana
1994 Jeep 147k Castrol 0w40
2014 Camry 16k TGMO 0w20
2010 Sebring 40k Valvoline 5w30
2014 HD Ultra 19k Valv20w50
2012 Toyota Rav4 24k Mobil 1 0w30AFE
#2613241 - 04/29/12 08:07 PM Re: Acronyms used at BITOG, make me a sticky [Re: wally6934]
teddyboy Offline
Loc: NC, United States
Outstanding job wally. We now have our own urban dictionary.
97 Camry M1 5W30 HM & OEM Filter
14 Camry TGMO 0W20 & OEM Filter
08 Volvo S60 M1 0w40 OEM Filter
#2619961 - 05/06/12 11:54 PM Re: Acronyms used at BITOG, make me a sticky [Re: wally6934]
Loobed Offline
Loc: Northern California, USA
AFAIK = as far as I know
FWIW = for what its worth
CRS = can't remember [censored]
Engine: 2001 GM 5.3L LM7
Current Fill: Valvoline Synpower 5w-30 w/Pure-One PL25288 filter
I.M.N Oil Enthusiast
#2625146 - 05/12/12 07:42 PM Re: Acronyms used at BITOG, make me a sticky [Re: wally6934]
circuitsmith Offline
Loc: Wash, DC
PBR = Pabst Blue Ribbon (what to drink when pouring PYB into your motor)
2006 Toyota Matrix 5-sp. 1zz-fe 5000mi/12mo OCI
Any major brand dino 5w-30 on sale
#2625235 - 05/12/12 09:37 PM Re: Acronyms used at BITOG, make me a sticky [Re: wally6934]
Capa Offline
Loc: Oklahoma
If you are ever invited to a BITOG party then BYOO means..,bring your own oil smile
#2639047 - 05/29/12 09:08 AM Re: Acronyms used at BITOG, make me a sticky [Re: wally6934]
Hokiefyd Offline
Loc: Top of Virginia
Thank you for compiling this list. Here are a few more:
ATF = Automatic Transmission Fluid
MTF = Manual Transmission Fluid
PS = Power Steering (system)
PSF = Power Steering Fluid
VMLNG = Valvoline MaxLife NextGen
VNG = Valvoline NextGen
VSP = Valvoline SynPower
Cheers,
Jason
2009 Honda Ridgeline RTL
2005 Acura MDX Touring
#2639291 - 05/29/12 01:03 PM Re: Acronyms used at BITOG, make me a sticky [Re: wally6934]
Artem Offline
Loc: Florida
shocked2 shocked that's a big list. I usually only see about 9-10 of those being used on the daily basis.
Good job guys
2015 Lexus ES300H with all the goodies - Factory Fill
2014 Mazda 3 Hatch i Touring 2.0L & 6spd - Mazda 0w20
#2643785 - 06/03/12 10:39 AM Re: Acronyms used at BITOG, make me a sticky [Re: wally6934]
garageman402 Offline
Loc: NorCal. USA
One more:
RLI = Renewable Lubricants, Inc.
Great list, BTW. I actually didn't know what BOGO was until now, thanks for posting this! :-)
-Bob
'71 402 BBC in '75 C30
'00 Montana 3.4L V6
'08 Buick Enclave 3.6L V6 VVT
#2643798 - 06/03/12 10:56 AM Re: Acronyms used at BITOG, make me a sticky [Re: wally6934]
Loc: NorCal. USA
Hey forgot this one in my signature!!
VVT = Variable Valve Timing
-Bob
'00 Montana 3.4L V6
#2648916 - 06/08/12 08:31 PM Re: Acronyms used at BITOG, make me a sticky [Re: wally6934]
zerosoma Offline
Loc: Omaha, NE
Good job everybody, I have some
HDS - Havoline Deposit Shield
MS - Mobil Super (some use it)
CQ - Carquest
QS - Quaker State (anything)
PZ - Pennzoil (anything)
HM - High Mileage (anything)
DW - Driveworks (filters)
MG - Microgard (filters)
GLO - Gear Lube Oil
and I also say PZHM (Pennzoil High Mileage)
and pretty universal sayings,
IMO - in my opinion
IMHO - in my humble/honest opinion
IRL - in real life
2004 Hyundai Santa Fe LX 3.5L V6 (125k) [Valvoline Max Life Next Gen 5w30]
#2655130 - 06/15/12 01:32 PM Re: Acronyms used at BITOG, make me a sticky [Re: wally6934]
ag_ghost Offline
Loc: SF Bay Area, CA
HF=Harbor Freight
66 Mustang (289)-Valvoline VR1 10W30
63 Galaxie 500 (390)-Chevron 10W40
99 Accord V6-Chevron 5W30
15 CR-V M1 EP 0W20
#2724604 - 08/25/12 07:46 AM Re: Acronyms used at BITOG, make me a sticky [Re: wally6934]
ottotheclown Offline
Loc: new york
What is MSS ? Mobil super what is the other s?
ottotheclown
#2724615 - 08/25/12 08:02 AM Re: Acronyms used at BITOG, make me a sticky [Re: wally6934]
Quattro Pete Offline
Loc: Great Lakes
Mobil Super Synthetic
'02 530i (Edge HM 10W-40)
'15 Q5 3.0T (Edge 5W-40)
#2737957 - 09/08/12 09:34 AM Re: Acronyms used at BITOG, make me a sticky [Re: wally6934]
tribocessive Offline
Loc: bay area california
DSA=dipstick spectral analysis.
2012 hyundai elantra touring gls at 55,000 miles eneos sustina 0w20 bosch D+ 3312 rl D4
