killing weeds without poisoning well
by oilboy123
07/24/16 01:27 AM
1999 ford expedition factory mercon v synthetic??
by merconvvv
07/23/16 11:40 PM
Buick 3800 - "Von Voyage" oil change?
by Alex_V
07/23/16 10:41 PM
Low oil level light on, but level not THAT low....
by gregk24
07/23/16 10:26 PM
Is SuperLube syn multi grease universal
by NattyBoh
07/23/16 10:05 PM
How come discount tire doesn't use jack stands?
by motor_oil_madman
07/23/16 09:41 PM
SAFETY ?: ramps in rear and jack stands in front
by SavagePatch
07/23/16 09:03 PM
Pennzoil ultra 5w30 back in stock at Walmart.com
by kohnen
07/23/16 08:37 PM
Homelite weedeater not getting fuel
by Drew99GT
07/23/16 08:26 PM
Stability issue on 2015 F250
by Donald
07/23/16 07:25 PM
2016 Tacoma 3.5L V6 4x4
by NavyVet88
07/23/16 07:10 PM
Question on 05 Nissan tranny w/120k
by NattyBoh
07/23/16 06:58 PM
Matt_P, tpragski, 182RG, BillHuang, jwilliamson185
58578 Registered Users
33 registered (Chewie, austinlunsford, c502cid, bamorris2, aquariuscsm, 4 invisible), 756 Guests and 18 Spiders online.
58578 Members
66 Forums
252174 Topics
#2605192 - 04/20/12 07:46 PM gas pedal sticks after i changed idle control valv
Caliberguy Offline
Loc: Arlington, Va
hi. i've changed idle air control valve and car idles proper. but now car gas pedal sticks a bit when first starting out...help??? is it throttle body cleaning? mechanic oiled cable from gas pedal and said cable seems ok
#2605213 - 04/20/12 07:56 PM Re: gas pedal sticks after i changed idle control valv [Re: Caliberguy]
bobfather99 Offline
Loc: Northwest Indiana
Probably a gunked up throttle body. Pull the sensors and give it a good scrubbing with throttle body cleaner.
05 Chrysler Town and Country 160,030 miles
Current fill, Peak conventional 5w30, Mopar filter
#2605230 - 04/20/12 08:11 PM Re: gas pedal sticks after i changed idle control valv [Re: bobfather99]
Rand Offline
Loc: NE,Ohio
probably EGR buildup on the throttle body.
Take it off engine and clean with rags and cleaner if possible.
also depending on the make/model some vehicles have a coating on the TB to help with buildup so be careful what you clean it with
In the future if you want help it would be helpful to at least list what type of car it is..
Edited by Rand (04/20/12 08:13 PM)
2015 Forester I-Premium 6MT
#2605269 - 04/20/12 08:42 PM Re: gas pedal sticks after i changed idle control valv [Re: Caliberguy]
Caliberguy Offline
Loc: Arlington, Va
Ford 5.0L v8 1991 Mercu Grand Marquis.
#2605270 - 04/20/12 08:43 PM Re: gas pedal sticks after i changed idle control valv [Re: Rand]
Caliberguy Offline
Loc: Arlington, Va
so i'll disconnect air filter assembly and i'm looking at throttle right? just clean that?
#2605330 - 04/20/12 09:51 PM Re: gas pedal sticks after i changed idle control valv [Re: Caliberguy]
L_Sludger Offline
Loc: NORTHCOM AOR
You probably fouled something in between the gas pedal and the throttle body on the throttle control sub-system while changing the IACV. Look under the hood and throroughly inspect the throttle linkage from firewall to throttle body, and look at the throttle body for obstructions in the full range of movement`
#2605503 - 04/21/12 05:52 AM Re: gas pedal sticks after i changed idle control valv [Re: L_Sludger]
Caliberguy Offline
Loc: Arlington, Va
i will check it. i don't recall touching anything when i installed the IACV. But i'll certainlygive it a look. THANKS
#3204432 - 12/02/13 10:00 PM Re: gas pedal sticks after i changed idle control valv [Re: Caliberguy]
MDettling Offline
Loc: Oregon
Caliberguy.
I know this is an old thread. The mechanic may have messed with the idle stop screw to obtain proper idle speed, which isnt even an idle speed screw (it's called a throttle stop screw I think) It's there to keep it (throttle plate) from closing all the way AND STICKING. I have a '89 Lincoln Towncar with the same engine. There is a procedure for adjustment. If you need the info, I can scan it from my Haynes manual.
Mike
