I was looking into buying some test strips to test my brake fluid. The only ones I could find were ones that test copper levels, not moisture. The manufacturer says testing for copper is much more important and is a more reliable indicator of corrosion, and that moisture is basically a non-issue in modern brake systems. The copper contamination comes from the copper coating on the inside of brake lines. When the corrosion inhibitors in the brake fluid wear out, copper starts showing up in the fluid (supposedly).
Quote:
Then there's the mistaken belief, now earning the distinction of “urban legend,” that water is brake fluid's worst enemy and the slightest trace of it demands an immediate system flush or dire things might happen……Now, new technology and standards are finally putting the decades-old moisture myth to rest. Especially since today's Anti-Lock Brake Systems and brake fluids are designed to reduce or eliminate moisture related problems. In fact, GM, Ford and Chrysler have no recommendation for brake fluid service based on moisture because it's not considered a safety threat or service issue.
Quote:
But while car owners can stop being hydrophobic about their brake fluid, a new guideline developed by a consumer protection group called the Motorist Assurance Program (MAP), points the finger at another culprit that over time can cause serious problems with ABS components. Copper. And it's an inside job. Recent government research conducted by the National Highway Traffic Safety Administration confirmed that copper can form deposits around the sealing surfaces of ABS valves, which means your car may take longer to stop in a panic situation. Other research finds that copper levels in the brake fluid are the best indicators that the fluid's corrosion inhibitors are losing their punch and major corrosion is just around the corner. MAP puts the red-flag level of copper at 200 parts per million. Anything above, they require the fluid be flushed and replaced.
Copper vs water
New brake fluid test puts end to age-old myth
Discuss.
Copper vs water
Discuss.
