Originally Posted By: Nick R
The equinox is unfortunately, not an option. I think her exact words were "If you want to put thousands of miles on cars gallavanting all over the country, you will be doing it on YOUR car". I had already thought of that, but I kind of expected the outcome.
My cruze comes with THESE tires
http://www.tirerack.com/tires/tires.jsp?...;autoModClar=LT
S speed rating, B rated for temperature, max load of 1,477lb and I generally keep them inflated to ~38-39psi. I think sciphi's right, I doubt power will be an issue. BUT, when we go to mt washington we WILL be going through on the vermont and NH backroads, which are rather ah, hilly. I was slightly more concerned about the transmission. And then to ohio, which is 500 miles of pure interstate driving each way
Can you manually hold a gear with your auto? Like 4th or 3rd? And does the torque converter lock in those gears? If you can't find out for sure then I wouldn't try the trailer alone for any real distances at interstate speeds. I've towed far too much on the interstate and I spent alot of time in 4th and more than you would think in 3rd (3800 rpm @55mph)with the Tracker. Think long steady grades into 30mph headwinds...
Adding the 4 buddies and gear is too much even for my level of disrespect for tow ratings... One of those guys will have to atleast take all the passengers and stuff in another car. You are going to have your hands full driving the car and keeping tabs on how its doing as well, so you don't need any distractions...
When we went gallavanting across the country at your age, we tented it, which made the drive enjoyable and stress free and cheap with 40mpg tanks and tent sites. Get a Eureka tent or something decent, a good air matress and sleeping bag. That's what I would do again anyways.
