I am reposting this UOA by typing it out by hand, as yesterday I tried to copy and paste my blackstone UOA report on here with no luck...
Here is the info
Duramax LBZ. 74,000 miles on engine. 12,400 on oil sample. Prior batch of oil was rotella 15w40. Makeup oil was 1.5 quarts. Amsoil EAO oil filter with filter mag installed.
Aluminum 3
Chromium 1
Iron 44
Copper 28
Lead 4
Tin 3
Molybdenum 54
Nickel 0
Manganese 1
SIlver 0
Titanium 0
Potassium 1
Boron 34
Silicon 8
Sodium 16
Calcium 973
Magnesium 1052
Phosphorus 1034
Zinc 1213
Barium 0
SUS Viscosity @ 210 F 75.8
cst viscosity @ 100 C 14.47
Flashpoint 425 F
Fuel % Antifreeze ?
Water % 0.0
Insolubles 0.4
TBN 7.0
Blackstone flagged the iron,copper and sodium as "high" and told me to keep an eye on coolant level, as they mentioned that the sodium could possibly be a coolant leak? I am confused to why they put just a question mark next to the coolant reading? I did change this oil out..and was wondering if there is any other way they could get higher sodium readings without coolant in oil? This may be a dumb question...but I do not have a cover for my fumoto drain valve, and am wondering if road salt could be built up inside of that opening and skewing my results perhaps?? In the mean time I am going to run some short intervals until I figure out what is going on with the sodium.
-Ponch
Here is the info
Aluminum 3
Chromium 1
Iron 44
Copper 28
Lead 4
Tin 3
Molybdenum 54
Nickel 0
Manganese 1
SIlver 0
Titanium 0
Potassium 1
Boron 34
Silicon 8
Sodium 16
Calcium 973
Magnesium 1052
Phosphorus 1034
Zinc 1213
Barium 0
Flashpoint 425 F
Fuel % Antifreeze ?
Water % 0.0
Insolubles 0.4
TBN 7.0
-Ponch
