95 Corolla, 200k miles.
Recently the front left side of the car started developing a spring mattress/furniture like squeak every rev at low speed, down to as slow as driving around in parking lot, and as soon as it reaches city traffic speed (say, 25-45mph), the wall reflection of the sound turns into ticking. It is not a high pitch scraping noise like a worn brake pad (the pads still have 2/3 left).
I've verified by jacking only one side of the front and take off the wheel, then let that corner free wheeling in mid air at reverse / drive in idle. This sounds seems to be from the outer CV joint. When I do the same on the other front wheel, I hear a clunk / tick like sound instead. I'm not sure if it is because the rotor is rattling in the hub or is it because of the CV joint going bad too. Overall the car do vibrate a lot at high way speed (65mph or higher).
I'm wondering if I should throw in a pair of new axles and wheel bearings due to the age, or should I just bring it to a shop and replace only the worn part. I understand many people say the original part from the factory is better than even OEM replacement, but I do feel that replacing them just in case at this age is probably going to save the diagnostic / additional alignment down the road. I am planning to keep this car for mom since she is so used to driving it and another car would make it difficult to adjust, especially a bigger car in a major city.
Any suggestion?
Any suggestion?
