The pattern on that graph is fairly typical for oils. Once the anti-oxidants get used up the oils thicken rapidly under these test engine conditions.
I do not know how Lube Control works. If you are having a problem with oil thickening you should consider using a different oil. Diesel oils of greater ratings have more oxidation resistance, particularly over gasoline engine oils with little or no diesel specifications.
aehaas
aehaas
