Smoked some baby backs today
by BeerCan
54 minutes 27 seconds ago
Ford FWD axle replacement
by 2009Edge
55 minutes 54 seconds ago
Saturn ac compressor
by spasm3
Today at 10:20 PM
looking for spray guns - analysis paralysis
by tomcat27
Today at 10:18 PM
WIX 51372 ADBV Failure
by WellOiled
Today at 10:11 PM
moly + engine coatings
by benjy
Today at 09:57 PM
Worth the upgrade?
by daves87rs
Today at 09:47 PM
Mr. Funnel does in fact work!
by TurboFiat124
Today at 09:46 PM
Will ATP205 help with a head oil leak
by NattyBoh
Today at 09:11 PM
Why is 100% gas more expensive in the city?
by TurboFiat124
Today at 09:06 PM
Trouble getting a copper pipe sweat fitting sealed
by NateDN10
Today at 08:58 PM
Murphy oil
by TurboFiat124
Today at 08:53 PM
NJ1911, SneakyTacos, DaveD, 8o8is, Texasdude74
58584 Registered Users
58 registered (AZjeff, abycat, ag_ghost, Brad_C, barkingspider, benjy, 8 invisible), 1373 Guests and 8 Spiders online.
58584 Members
66 Forums
252216 Topics
Page 2 of 2 < 1 2
#2599582 - 04/14/12 04:34 PM Re: can't get tire off car [Re: dishdude]
fdcg27 Offline
Loc: OH
Not necessarily.
The old Impreza is on steelies, and the right rear was locked solid to the hub after only four months.
The usual combination of force and desperation got it off after protracted effort.
12 Accord LX 53K HGMO 0W-20
09 Forester 67K PU 5W-30
02 Accord 144K GOil 5W-30
01 Focus ZX3 112K M1 5W-20
95 BMW 318iC 159K Delvac 15W-40
#2599606 - 04/14/12 05:06 PM Re: can't get tire off car [Re: Caliberguy]
mechtech2 Offline
Loc: Chicago Area
Hit the tire hard with a sledge . [hit from the inside to the outside]
#2599707 - 04/14/12 07:23 PM Re: can't get tire off car [Re: Caliberguy]
Caliberguy Offline
Loc: Arlington, Va
these are aluminum wheels, turbine style. i'l try these hints tomorrow. i'm going to go at it with sledge
#2599723 - 04/14/12 07:42 PM Re: can't get tire off car [Re: Caliberguy]
yonyon Offline
Loc: NJ, USA
Do not hit aluminum wheels directly with the sledge hammer unless it's got a rubber face. Those are pretty rare. Hit the tire, not the wheel. The tire won't crack from hitting it with the sledge. Chunks of the wheel just might break off if you hit them with it. If hitting the tire absorbs too much of the impact you can overinflate the tire to make that cushion harder. If you must strike the wheel, at least protect it with a wooden board or block.
Also, while hitting from the underside delivers the force in the right direction, you can probably get a better swing in from the outside and that may more than make up for it.
#2599736 - 04/14/12 08:07 PM Re: can't get tire off car [Re: Caliberguy]
eljefino Offline
Loc: ME
For whatever reason a 2x4 or 4x4 works best for me. About 4-5 feet long. Pressure treated is a bonus. Anything bigger is too much to handle.
#2599874 - 04/14/12 11:37 PM Re: can't get tire off car [Re: Caliberguy]
Ken2 Offline
Loc: Washington St.
Loosen the lug nuts, drive very slowly ahead, hit the brakes. If it is still tight, drive very slowly back, hit the brakes. If it is still tight, do it again just slightly faster.
No job too small; no hammer too big....motto of Brute Force & Ignorance Car Repair
Every gun that is made, every warship launched..a theft from those who hunger and are not fed, those who are cold and not clothed.
Gen. Eisenhower
#2600116 - 04/15/12 10:40 AM Re: can't get tire off car [Re: Caliberguy]
Jarlaxle Offline
Loc: New England
This was common on older Panthers with aluminum wheels...I usually hooked a crowbar against the LCA or spindle and gave it a hard yank. If that didn't work, a couple thumps against the tire with a weighted mallet usually did.
1979 Coupe de Ville, 542 stroker, 15W-40 Super Tech, Delco
2011 Crown Vic P71, 5W-20 Valvoline NextGen, Purolator
2012 Suzuki AN400A, 10W-40 ST, Delco
#2600137 - 04/15/12 11:09 AM Re: can't get tire off car [Re: Ken2]
yonyon Offline
Loc: NJ, USA
Hey, if you think using a hammer the size of a full size Ford station wagon is appropriate to loosen a wheel that's a little stuck, that's cool. I have found 3 to 10 pounds is usually a big enough hammer most of the time.
#2600270 - 04/15/12 02:21 PM Re: can't get tire off car [Re: mechtech2]
mechtech2 Offline
Loc: Chicago Area
Note that I said TIRE, not WHEEL.
[And use the flat side of the sledge head].
#2600288 - 04/15/12 02:39 PM Re: can't get tire off car [Re: Caliberguy]
Caliberguy Offline
Loc: Arlington, Va
the hammer inside-outside hit worked!!! wheel cam right off after 2nd blow. no damage.
I appreciate all the help I recieved here. THANKS EVERYONE
#2600614 - 04/15/12 10:08 PM Re: can't get tire off car [Re: Caliberguy]
Carbon Offline
Loc: near Chicago
Try a wheel puller. I hope you haven't ruined your wheel bearings with the prying and pounding. If you have 6 or 9 spokes, the biggest or second-biggest should be good.
http://www.harborfreight.com/4-piece-three-jaw-puller-set-40965.html
#2600708 - 04/16/12 01:21 AM Re: can't get tire off car [Re: Carbon]
yonyon Offline
Loc: NJ, USA
There's no need for a puller. He's got the wheel off. I believe the hammering he did wouldn't be against the wheel bearing so much as the differential carrier bearing. That's a mighty big bearing and with the mass of brake parts, axle shaft, and diff all taking up some of the impact it shouldn't be a concern.
My memory must be broken. I was thinking this was a rear wheel.
Edited by yonyon (04/16/12 01:25 AM)
#2601048 - 04/16/12 02:26 PM Re: can't get tire off car [Re: Caliberguy]
cutter Offline
Loc: Philadelphia, PA
When my alloys get stuck to the rear drums, I use my breaker bar that I used to take the wheel off to wedge in between the spokes and the drum. Break it loose, spin the wheel to the next spoke, easy.
Page 2 of 2 < 1 2
