Based on the results Blackstone recommended reducing the milege by 400 miles. I am going to reduce by another 1,000 miles just for a little insurance. This means I'll be changing oil at 13,000. The reduction of 1,500 miles will onlly add one additional oil change in the next 130,000 miles and will be well worth the cost. Especially considering the cost of an engine.
The OLM was at 25% on the first analysis and at 9% on the second analysis. So next time the OLM should be around 20%.
First analysis
OIL Pen Plat 5w-30
MILES IN USE 11,985
MILES 63,125
SAMPLE TAKEN 8-22-11
OLM 25%
Second Analysis
Oil Penn Plat 5w-30
Miles in use 14,444
Mileage 77,569
Sample taken 3-17-12
OLM 9%
ALUMINUM 3 8
CHROMIUM 1 1
IRON 20 37
COPPER 2 4
LEAD 0 0
TIN 0 2
MOLYBDENUM 55 47
NICKEL 0 0
MANGANESE 1 2
SILVER 0 0
TITANIUM 0 0
POTASSIUM 0 3
BORON 31 7
SILICON 6 5
SODIUM 4 11
CALCIUM 3234 2416
MAGNESIUM 12 17
PHOSPHORUS 638 597
ZINC 738 704
BARIUM 0 0
INSOLUBLES TR Tr
WATER 0 o
FLASHPOINT ºF 400 380
SUS VIS 210ºF 62.6 64.1
cSt @ 212ºF 10.96 11.39
TNB 2.3 1.7
SECOND ANALYSIS Blackstone comments:
You noted the oil life monitor said 9% remaining and we agree that this oil was right at the end of its useful life. In fact, the accumulated iron (from steel parts) was enough that we suggest sticking with about 14,000 miles on the next oil to see what develops from here. It’s important to note that about 20% of the oil remains in use between oil changes, so the next oil is actually starting off with a touch more metal than this oil change did. The slightly high viscosity isn’t a concern. The TBN of 1.7 is still strong. No problems found at 77,569 engine miles.
First analysis
OIL Pen Plat 5w-30
MILES IN USE 11,985
MILES 63,125
OLM 25%
Second Analysis
Oil Penn Plat 5w-30
Miles in use 14,444
Mileage 77,569
OLM 9%
ALUMINUM 3 8
CHROMIUM 1 1
IRON 20 37
COPPER 2 4
LEAD 0 0
TIN 0 2
MOLYBDENUM 55 47
NICKEL 0 0
MANGANESE 1 2
SILVER 0 0
TITANIUM 0 0
POTASSIUM 0 3
BORON 31 7
SILICON 6 5
SODIUM 4 11
CALCIUM 3234 2416
MAGNESIUM 12 17
PHOSPHORUS 638 597
ZINC 738 704
BARIUM 0 0
INSOLUBLES TR Tr
WATER 0 o
TNB 2.3 1.7
