Originally Posted By: LoganC
Like the old saying goes: Only rich man can buy cheap things....because you have to keep buying them.
It may be kind of spendy but it is custom formulated for your engine and your needs. But if there is a regular oil that will do the same for lower cost it makes no sense to spend the money
The maker of that oil is on Charger forum. A Dodge Charger has a 100,000 mile 5 year warranty. Does Q-Blue satisfy the warranty (API certification etc)? Will they pay if something goes wrong? How do you know it is custom formulated to a specific engine/need? You would have to do a side by side test with another standard oil. Amsoil and Redline at the same price would be better.
Quote:
QB Catalyst uses special proprietary shear, viscosity, and anti-wear technology originally designed for severe military and space applications which reduces wear 90% and friction over 40%
"... special proprietary shear, viscosity, and anti-wear technology." Reduces wear and friction over what; sand, glue, cement? That whole website is hokum.
Quote:
The thinking here was that if Quantum Blue cut wear by means of friction reduction then this might offset any viscous loss due to being a 15-45 blend versus the 0-30 Mobil blend currently in the sump.
Read more:
http://www.gmhightechperformance.com/tec...l#ixzz1rlwbyzKe
They quote an article from GM High Tech Magazine, but that magazine is not from General Motors. It is just like any other magazines. That article was a sales pitch. There is no 15-40 grade.
Quote:
5w20,
5w25, 7.5w23, 8w35, 10w35, 12.5w32,12.5w35, 12.5w37, 12.5w40, 15w45, 16.3w37.5, 17.5w45, 20w35 & 20w50 racing oils:
More nonsense oil grades.
Custom blending? You tell them what you have. They go to the BITIG UOA section and see what works good in a similar setup as you describe. They go to the store and buy that oil. They pour it into a plain Jane gallon jug, print a label, with your name, on a bubble jet printer, and stick it on the jug. After you purchase the oil, they continue to mail you testimonials of fictitious people claiming how wonderful their stuff really is.
