Originally Posted By: Hokiefyd
I hate to belabor the point, but is the Toyota stability control system different from any other? I've owned a lot of vehicles with stability control, and none have talked about recalibrating the stability control system after an alignment. I don't even remember seeing it for my 2011 Camry.
See these two print-outs that I uploaded from the Prius service manual:
https://docs.google.com/file/d/0B8-5xrBaLKaBNUxyYzI2T09FeWc/edit (bottom of second-to-last page.)
https://docs.google.com/file/d/0B8-5xrBaLKaBdWFmNGZnQTBVenM/edit
The shop manual clearly states that a yaw rate/acceleration sensor calibration is necessary after a front-wheel alignment.
Originally Posted By: ComfyShorts
On newer Hunter alignment racks there is an option that comes up after the alignment is complete for vehicles where steering angle sensor and others stability related sensors to be re calibrated. Is it really important? Its not critical if vehicles alignment stays close to factory specs. But if large alignment adjustments are made its very important to re calibrate.
@Critic: Don't re calibrate on your own. When aligning, tech puts vehicle in exact steer ahead position based on HIS steering wheel centering BEFORE front toe adjustment. In other words if your steering wheel centering differs from the tech who did the alignment, your re calibration is inaccurate in relations to the actual alignment even if you centered steering wheel perfectly. I'm tired at the moment let me know if I need to clarify something.
I am somewhat familiar with the Hunter code link system. We tried on my Prius and it did not work correctly, and the EPS started doing weird things. The steering became stiff for some reason. After clearing the stored data and doing a calibration with Techstream, all was well again.
The Prius factory service manual presumes that the alignment was done correctly and that the steering wheel was properly centered. The instructions on the shop manual do not state that the zero point calibration needs to be performed on an alignment rack or in conjunction with an alignment. You only need to put the steering wheel in the steer ahead position to initiate the process. One may have replaced a VSC component that did not require an alignment, and may require a zero-point calibration. At least that is my understanding, and has not caused me any problems so far?
