My fathers 05 TSX with the K24A2 has been using oil as it approached 100k. The car has always used conventional oil from dealership oil changes. (I thought that was the problem) They use "bulk oil" 5w20. The car calls for 5w30.
It was using 1 quart every 2k. Not that that is a lot but I don't like it. No leaks/smoke out the back. Recently I switched to Penzoil High Mileage 5w30. Checked it after 800 miles of use and it required a little less than 1/2 quart.
Has anyone found a motor oil that can help this motor burn off less? I've read this motor is notorious for using oil, but I feeel this is a bit much for a 100% stock automatic TSX that never really revs about 5k.
