- Joined
- Dec 28, 2011
- Messages
- 5,043
She turned 30k mark. Going to replace the trans pan with a PML oversize cover (magnetic drain plug), clean the screen, and fill it up with MaxLife trans fluid. Going to install the MagnaFine filter as well. Changing a $16 filter every 30k miles isn't going to be an issue for me so I'm going for it.
Also going to change the front and rear differential fluids and the transfer case.
Is it ok to use the MaxLife in the transfer case as well??
