Half Price GTX 15W-40 @ REPCO in Oz
by SR5
Today at 03:27 AM
1991 Sierra rear brake squeel
by sr17
Today at 12:57 AM
2015 Silverado Diff Fluid Change
by Realtech214
Today at 12:25 AM
Undercarriage Rust Management
by OpenClose
Yesterday at 11:31 PM
New used tires
by gfh77665
Yesterday at 11:29 PM
Hybrid and ROI (Return Of Invesment)
by HTSS_TR
Yesterday at 11:14 PM
Best Walmart stocked wiper blades?
by aquariuscsm
Yesterday at 10:54 PM
What Ohm antenna wire to use?
by daves66nova
Yesterday at 10:46 PM
Turtle Wax Passed The Test
by RevRider
Total FLUIDMATIC G6 SYN ATF, 13.7k mi OCI, 34k mi
by Emperors6
Yesterday at 10:17 PM
Honda NC700X Red Line 10W30, ~5,000 miles
by bulwnkl
Yesterday at 10:13 PM
If you liked the Fram AirHog Filters
by rrounds
Yesterday at 10:07 PM
Timmytimmy, Peakboy91, TimingBeltKing, watergate528, iamtheanimal
57996 Registered Users
23 registered (fdcg27, Indydriver, Drosselmier, 2015_PSD, Char Baby, 4 invisible), 611 Guests and 302 Spiders online.
57996 Members
66 Forums
249470 Topics
Page 1 of 2 1 2 >
#2594842 - 04/09/12 07:48 PM Effects of engine overfill
penz08 Offline
Loc: new brunswick canada
What are the symptoms of an overfilled engine? Is overfiled by one quart will make my engine feel slugih?
#2594849 - 04/09/12 07:55 PM Re: Effects of engine overfill [Re: penz08]
dave1251 Offline
Loc: Maricopa, AZ
You have some questions today don't you? One quart you probably will not notice a thing. If you over fill you sump too much you start to have a problem of your engine seals bursting off the engine because of too much pressure but I have never seen that I just read about it.
don't use.
#2594852 - 04/09/12 07:57 PM Re: Effects of engine overfill [Re: penz08]
dparm Offline
Loc: Chicago, IL
Depending on the design of the oil pan you could also get frothing as the crankshaft skims the top of the oil.
2011 BMW M3 sedan ZCP
#2594854 - 04/09/12 07:58 PM Re: Effects of engine overfill [Re: penz08]
Jeffy_D Offline
Loc: missouri
Sluggish performance would be the least of your worries. If its overfilled and contacts the piston rods, its will cause the oil to foam , and where theres air, theres no lubrication.
Every motor is different, I wouldnt risk it. Drain it or at least get a syphon pump.
Edited by Jeffy_D (04/09/12 07:59 PM)
10 titan 70k castrol magnatec/fram TG
12 sonic 55k AC Delco oil and filter
#2594855 - 04/09/12 07:59 PM Re: Effects of engine overfill [Re: dave1251]
penz08 Offline
Yes I do have a lot to ask! One time my engine was shaking so much, i had new plugs oe, i think the stupid mecanic overfilled by one quart, and i think its too much for a 1.6L.
#2594860 - 04/09/12 08:01 PM Re: Effects of engine overfill [Re: penz08]
Corvette Owner Offline
Loc: Waldorf, Maryland
It can cause aeration of oil, which can be bad. Pull dipstick after car is running and see if you see bubbles.
What percent is one quart of full oil change?
Vehicles:
98 Corvette
06 Murano
96 Chevy Van (Custom Conversion)
14 Chevy Impala
10 Starcraft Boat
13 Buick Enclave
#2594863 - 04/09/12 08:02 PM Re: Effects of engine overfill [Re: penz08]
A1BadPizzaGuy Offline
Loc: FL, United States
The worst thing I've actually seen is foaming the oil. But I've poured a quart of MMO on top of an already full sump, and when I drained the oil about 500 miles later, there was no foam.
#2594867 - 04/09/12 08:04 PM Re: Effects of engine overfill [Re: Corvette Owner]
penz08 Offline
The max is 3.3L
#2594872 - 04/09/12 08:05 PM Re: Effects of engine overfill [Re: penz08]
The Critic Offline
Loc: Walnut Creek, CA
On a 2nd gen Prius, 1/4 qt will likely result in reduced fuel economy and oil pooled in the throttle body.
Larger amounts of overfill supposedly, according to a TSB, will result in a no-start.
11 Prius - 129k - M1 EP 0w20/OE
07 Accord 2.4 - 111k - M1 5w20/FPS Filter
10 Altima 3.5 - 34k - M1 EP 5w30/FU
92 Previa - 160k - Chevron 5w30/Wix
#2594874 - 04/09/12 08:06 PM Re: Effects of engine overfill [Re: penz08]
crazyoildude Offline
Loc: New Jersey
you will get lots of bubbles
#2594877 - 04/09/12 08:09 PM Re: Effects of engine overfill [Re: penz08]
Lead Shoes Offline
Loc: Mn
Originally Posted By: penz08
The max is 3.3L
I wouldn't worry, I've overfilled mine by a quart and just let it burn off with no ill effect or blown seals.
1992 BMW 325i 176k
Castrol 0w40/Mahle
#2594878 - 04/09/12 08:10 PM Re: Effects of engine overfill [Re: The Critic]
penz08 Offline
wow, is it that bad? My car got a 1.6L , economical on gas, is smaller engine are more sensitive to overfill?
#2594883 - 04/09/12 08:13 PM Re: Effects of engine overfill [Re: penz08]
Lead Shoes Offline
Loc: Mn
What car is this exactly?
1992 BMW 325i 176k
Castrol 0w40/Mahle
#2594896 - 04/09/12 08:22 PM Re: Effects of engine overfill [Re: penz08]
silverrat Offline
Loc: Ontario
I know a place that opened one drain plug on a 996 and not the other one, and then poured 10 liters of oil in it. It was smoking and leaking from a seal.
03 Civic Si(R) - Assembled in Swindon, England
Long Live the Manual Transmission drive
#2594901 - 04/09/12 08:26 PM Re: Effects of engine overfill [Re: penz08]
Gene K Offline
Loc: Decatur AL USA
It depends on exact engine design. On the roadcourse 2.0L DOHC Neon routinely ran 1 Qt Low to reduce the number of spun bearings caused by aeration of oil that occurred when the crank contacted oil. On the other hand Corvette LS1's routinely ran 1 qt overfilled to reduce the chance of uncovering the pickup in High-G, High-RPM Sweepers.
Gene
Page 1 of 2 1 2 >
