I've been using 85 on any vehicles I've serviced (generally with M12 lugs, various thread pitches), unless I knew it was say a truck that took higher torque. Never had a problem. The difference between 80 and 85 as far as how much more it turns, I've seen to be very very small, say smaller than a 1/16th of a turn of the wrench.
I'm sure there is a [scientific] way to calculate torque spec based on stud/bolt thread size, thread engagement, pitch, seat type (angle, ball, flat etc), and material of stud and wheel. And it makes me wonder if there is such a thing as 'absolute/terminal' torque, such a spec that anything beyond this spec would start to stretch the stud/bolt. I don't know if that makes sense but I hope you get what I'm thinking. I figure it's really difficult to torque beyond this with conventional tools, 1/2 or 3/8 ratchet, which is why I generally go by feel when doing torque on fasteners, except that of wheels (because a 20-in 1/2-drive breaker bar can put on some torque), and axles, and of course critical engine assemblies or anything that's smaller than M10
Originally Posted By: toyotaguy
I googled Toyota corolla 09 torque spec. States 76 lbs. maybe I should just set it to 80 and be done
