T typ901 Joined Jul 13, 2008 Messages 897 Location N. 'Burbs of Chicago, IL Apr 6, 2012 #1 For my '01 M-B E320. Just wondering if anyone has any observations of one being better quality than the other. Both are within a couple of dollars of each other. Thanks.
D dparm Joined Apr 19, 2010 Messages 13,663 Location Frisco, TX Apr 6, 2012 #2 Bosch is likely not even making the plug wires -- a lot of their aftermarket stuff like that is outsourced. Who makes the OEM ones?
T typ901 Thread starter Joined Jul 13, 2008 Messages 897 Location N. 'Burbs of Chicago, IL Apr 6, 2012 #3 Originally Posted By: dparm Bosch is likely not even making the plug wires -- a lot of their aftermarket stuff like that is outsourced. Who makes the OEM ones? Not sure who is OEM- I had heard it is Bosch, but I think that is speculation. I have not see any identifying marks or info on wires myself.
A antiqueshell Joined Mar 2, 2012 Messages 5,133 Location chicago, Illinois Apr 6, 2012 #4 I never heard that Bosch is out-sourcing plug wire sets. I do know that at one time Bosch vendor Bremi was supplying the metal jackets for some boot wires. I'd go with whoever made the OEM stuff. Bosch is very good for critical ignition components.
D dparm Joined Apr 19, 2010 Messages 13,663 Location Frisco, TX Apr 6, 2012 #5 Like I said, I'm not sure. A lot of the stuff branded as Bosch is not made by them. Doesn't mean it's inferior though. Wipers, plugs, and oxygen sensors are some of their core offerings in the consumer market.
T The_Eric Joined Mar 31, 2010 Messages 6,266 Location Iowa Apr 6, 2012 #6 These are from an OE supplier to MB. Altrom Wires
A antiqueshell Joined Mar 2, 2012 Messages 5,133 Location chicago, Illinois Apr 6, 2012 #7 Beru is also an OEM supplier to VAG, BMW, MB, and a lot of other European makers. But I THINK they all supply OEM alternating so you'll find identical OEM part numbers on parts from any of the three. Here are the links Bremi (select english) http://www.en.bremi.de/b Beru http://www.beru.com/products/ignition-technology/beru-high-voltage-connecting-system Bosch http://www.bosch-automotive-catalog.com/...changeCountry=1 Last edited: Apr 6, 2012
T The_Eric Joined Mar 31, 2010 Messages 6,266 Location Iowa Apr 6, 2012 #8 Originally Posted By: antiqueshell Beru is also an OEM supplier to VAG, BMW, MB, and a lot of other European makers. But I THINK they all supply OEM alternating so you'll find identical OEM part numbers on parts from any of the three. Here are the links Bremi (select english) http://www.en.bremi.de/b Beru http://www.beru.com/products/ignition-technology/beru-high-voltage-connecting-system Bosch http://www.bosch-automotive-catalog.com/...changeCountry=1 You probably noticed but the wires in my link are made by Beru.
A antiqueshell Joined Mar 2, 2012 Messages 5,133 Location chicago, Illinois Apr 7, 2012 #9 For anyone that is interested here is the product finder for Beru: http://www.beru.com/aftermarket/product-finder
T typ901 Thread starter Joined Jul 13, 2008 Messages 897 Location N. 'Burbs of Chicago, IL Apr 8, 2012 #10 Thanks all for the input. I think I will stick with Bosch. As they are reasonable at 135 a set.
F flanso Joined Dec 26, 2006 Messages 428 Location Tampa, Florida Apr 9, 2012 #11 I worked in a store that sold both. I do not think the Bosch were nearly as good as the STI. Get a look at both, it will answer your question.
